Subwoofer recomendation for home audio/stereo
TechnoKid
5,575
I have JBL Studio Series II S36 bookshelf speakers, powered now by a harman kardon HK3480 (see my previous thread about the nakamichi going out. Aside--this harman receiver is a nice receiever, plenty of depth, power and clarity in music. It at least matches the sound from the previous nakamichi reciever2 i had, but, perhaps the nakamichi wasn't sounding so great as it was failing).
Since these speakers lack low bass extension by its obvious 6" woofer size, i was looking to get a small subwoofer. Are there any in particular you'd reccomend for music? In otherwords the bass has to be fast and clean, so I don't think a 12" sub would be ideal. Perhaps a 10"? I know the names of SVS and Hsu, but are these not more for movies/home theater and not for music?
If the sub costs too much, i'm just going to get bigger speakers, possibly JBL S312, or the E100, or some floorstanders with a bigger woofer than what I have right now. I think going with bigger full range speakers might be a better idea overall than gettin a sub. I'm constantly on the lookout for the JBL S38II bookshelf speakers on ebay, basically a S36II with an 8" woofer in a ported encolure.
////revision: I listen to music a lot, so this sub wouldn't really be intended to be a "movie/HT" sub, just something to add some extension to the S36ii i have. I think i may get that 10" $125 dayton for now, while i reasearch building bigger speakers, or builind my own sub.
MustISO
12
Velodyne, DefTech, B&W would be nice.
BTW, I have the JBL studios. I use a JBL 12" sub.
spidey07
65,469
nothing beats a good sub.
don't worry about size at the size of the woofer doesn't matter. Its really the performance of the enclosure and woofer so a 15" woofer can sound great and so can a 8 or 10.
as far as value SVS and Hsu are superb. Both are great for music and movies and really can't be beat in that price range.
Also, bigger speakers (until you get into the 5000 per pair range) will never go as low and produce good clean bass as even a decent sub.
If you want good bass on the cheap the sony WM10 is great.
dr150
6,570
24
ACI (audioc.com)
Hsu Research
SVS
VMPS
AV123.com
Google them. These will cover all your needs.
TechnoKid
5,575
THe sub i was acutally looking at was the PSB Subsonic 6i, but after reading a couple reviews, the bass is not as fast or tight as I'd like it for music. This sub however tested very well in Sound & Vision's subtest. Has the most uniform bass, and great low extension. 2004 of september was the issue on this article.
however, on this review: PSB SubSonic 6i (PDF in a webpage) they say the bas lags a bit, not that great for music.
edit: the review isn't availible anymore on sound&vision's webbie, but i do have the PDF of teh sub review
dr150
6,570
24
PSB is a good brand but doesn NOT COMPARE to the ones I listed above....
Muadib
18,123
912
Originally posted by: ThisIsMatt
Originally posted by: Muadib
How much are you willing to spend? The recomendations won't mean much if they're outside of your price range. Here's one that will blow you away. It's worth every penny of the 4k they want for it, but you can find it cheaper.
Tweeter: 1.1 in. high-resolution silk dome, Neodymium magnet
Damn, my sub doesn't have a tweeter :(
I'm thinking that's a typo. The guy that showed it to me didn't mention it, and I didn't see it.
Tiamat
14,068
Budget <150$ = Dayton 10" 100 Watt subwoofer mentioned above.
Budget <500$ = SVS PB10 mentioned above.
Budget <1500$ = B&W PV1 (These are awesome)
Budget = nonissue: Krell Master Reference Subwoofer (Best subwoofer in the world imo)
ThisIsMatt
Banned
Aug 4, 2000
11,820
Have you, or the person that referred you to it, ever heard it?
Howard
47,982
11
If my budget was greater than $500 I would never buy a subwoofer.
olds
50,120
776
Muadib
18,123
912
Yes, of course. If you have a dealer in your area, you should too.
Muadib
18,123
912
Why not?
Howard
47,982
11
Why not?
I would build.
Apex
6,511
www.gotapex.com
HT: Get a sub
Music: Get full range speakers
spidey07
65,469
HT: Get a sub
agreed.
but to get really good bass out of full range speakers you need lots of dough.
TechnoKid
5,575
Hmm...well it looks like i'm prob just going to get some bigger full range speakers, floorstanding instead of the bookshelf I have now. This is for the upstairs listening room. I suppose I could then use the bookshelfs in my room downstairs, paired with that dayton sub that $150 ($99 on sale sometimes).
Here is a Text (pdf) to that sub review from sound and vision which includes the PSB subsonic 6i i was orignally looking at. It has some pretty inpressive numbers. 93db @ 20Hz. But i dont think the 12" is ideal for stereo music lsitening.
This is not going to be used for movies just yet, though i certainly understand that there are subs that are good for both music and movies. I just want more depth and extenstion added to the S36ii bookshelfs i have.
My price range about now would be under $500. It looks like that dayton sub might be a good option at $150 to add some more bass to these JBL's i have. But for $500 i could score some used paradigms, or jbl studio series speakers. I'd prob go for dual 8" (the e90) or the dual 10" (E100) or the S312ii which is a single 12" woofer, or even the S310 which is a single 10" woofer.
