Subwoofer question
pontifex
43,804
46
If I have a subwoofer that has a speaker on the right side of the unit (when facing the front of the unit), will putting it next to a tv stand on the left side of the stand be an issue? It will be a few inches from the side of the stand if that helps.
pic for better example: http://pics.bbzzdd.com/users/pontifex/example.jpg
kalrith
6,628
7
Can you turn the sub so that the woofer faces away from the wall? I would think that would be better. I'm not an expert on these things though, so hopefully others will chime in.
pontifex
43,804
46
If I get the unit I want, I think the display is on the subwoofer, so if I turned it around, I wouldn't be able to see what setting it is on.
Tiamat
14,068
shouldn't be much of a big deal. Whats wrong with putting the subwoofer to the right of the TV stand?
pontifex
43,804
46
My ps3 and DVD player are on the left side and I don't want to move them to the right side. Oh, and the stereo I connect through so I can use my headphone is on the left side. Can't move that to the right side as there is no room.
Tiamat
14,068
The cable to hook up the subwoofer is that short?
