Subwoofer measuring techniques
Schadenfroh
38,416
4
What is the proper way to measure a subwoofer's size (IE 12" versus 10"), is it rim to rim or cone to cone?
The Subwoofer in my home theater system went out and I am looking for ways to save some money by using the existing enclosure. I am looking at a car stereo subwoofer to use in its place, is this a bad idea?
Looking at this car stereo speaker to replace my dead home subwoofer (do not mind modifying the enclosure).
Thanks
PurdueRy
13,837
4
Thanks
The normal way to measure a driver is from just inside the surround(rubber or other material surrounding the cone) to just inside the surround on the other side.
However, this really isn't a critical measurement. The more useful measurement is the radiating area of the cone which takes a bit more work to measure yourself. However, the manufacturer often provides this.
erwos
4,778
You have to remember that car stereo subwoofers and home theater subwoofers are made for entirely different spaces. Google for "cabin gain".
vi edit
62,484
8,344
Like these guys have said, it's not a simple drag and drop solution. There are MANY factors that go into what makes a good sounding sub.
It would help if you could start with what your existing sub is.
I've spent the last 2 months digging through the specs and fundamentals of sub building and put about 20 hours so far into building my own. Should wrap things up this weekend.
:eek:
jtvang125
5,399
51
Subs whether for home or car are measured from edge to edge. So a 10" sub will be a full 10" in diameter. Of course the mounting hole is going to be smaller and this varies between manufacturers.
Like others have mentioned it's a bit more complicated than just dropping in a new sub. Most HT subs are ported and this complicates things even more because a port is designed to match a particular sub. It can sound terrible to okay depending on the sub.
I have tried using car subs on my HT before. It was 2 10" in a sealed enclosure with about 300w going to them. They sounded pretty good but you will have to place it in a corner for it to sound good unlike a HT sub where you can place it just about anywhere and it'll sound good.
