Subwoofer has hum. Toss it?
Muse
In January 2003 I bought a DLS 100 watt subwoofer from Parts Express, paid about $131 shipped. It's been little used, it usually isn't plugged in. But last couple times I plugged it in, it hummed pretty noticeably even when not driven. Of course, it remains unplugged now, since it's in my computer room (doubles as home theater, office).
Do I have to get a new subwoofer, or is it possible I can get the hum out of this one?
Normally, I watch my DVDs using earbuds. No acoustics issues, I hear dialog better, don't disturb my neighbors, but certain movies deserve the full 5.1 treatment. And that's not the same without a house shaking subwoofer. :awe: Also, of course, if I have a guest, the 5.1 is the way to go.
On a side note, I have a question for a friend of mine. He bought a new Velodyne sub (not sure what model), and it works fine with everything except his computer. When he connects his computer (via stereo to RCA, I think) to his receiver, his sub hums constantly even when he's not sending any sound to it. Does anyone have thoughts on this problem? Sorry I don't have more or better info on it, but I'm just going off of memory on this one and don't have access to the system.
Edit: Oops, I deleted my first question once I realized yoyo asked the same thing.
Yup. That's it. It's pretty common for plate amps to pick up a ground loop hum. The cheater plugs can often fix it.
Ground lift? Yes, I have several. I usually use them to allow me to plug in a grounded plug to an ungrounded outlet, happens to be often. For instance, my wet-dry vacuum.
I turned on the subwoofer a few minutes ago and hear no hum. 😱 Not sure what's up with that, last times I turned it on the hum was pretty loud. I'll have to run some tests...
I think it depends on what else is running on that circuit. Fans, radios, vaccuums, ect being run at the same time on that same cicuit can provide noise on it.
sometimes is a combination of items on the circuit that could generate the ground loop. Many times its the cable box's fault. Sometimes, a refrigerator when the compressor is going.
