Subwoofer/Bass Set-Up | HELP!!!
ThatSecondGuy
Okay I have done my research and have found these sites:
Link:1
Link:2
I was just wondering if I have all the essential supplies here to set up a car bass/subwoofer system? *Excluding all Tools/Handware needed* Thanks. 🙂
If your headunit has RCA outputs for subwoofer, then yes. By the way... you'll want to step up to a real 8 gauge wire cable. Those cheap kits only look like 8 gauge, but most of the wire is plastic insulation. If you are on a budget then at least with the kit you chose at $18 you get the fuse and miscellaneous parts you may eventually use. Just go to Home Depot/Lowes and buy real 8 or 4 gauge power wire.
