Subnets/Routers/Switches
Schoolies
Ok, question.
1) If you have windows 2000 server, what would be the point of having a router if 2000 handles DHCP?
2) what is the point of having routers and switches connected together on the same network? What is the advantage?
3) If I have my 2000 server set up to have multiple subnets, how do i tell "these computers over here" to have this subnet, and "those over there" to have that subnet?
Ok, thanks. :)
MoMeanMugs
1,663
1)to use the net without bogging the server among many other reasons I am too lazy to list
2) speed among other things I am too lazy to list
3)DHCP pools
BTW, I hope you know the difference between a switch and a router, as it doesn't seem to me that you do.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
What are you, some kind of network salesperson?
Drop the cable and please step away from the network.......
You should be feelin' the need to read ....
Good Luck
Scott
pcmark
1,730
== You could use Windows 2000 Server as a "router", if that floats your boat, but it's really only an ethernet router. Try plugging your ISDN, Frame Rellay, or T1 into it :)
== They perform different functions, that's why. You need a router if you want to reach networks that aren't on your local network. Routers create broadcast domains, and use logical Network addresses( IP address, IPX address, etc). Switches create collision domains, and use MAC addresses. I could go on and on, but...
== DHCP scopes my friend.
spidey07
65,469
<< Drop the cable and please step away from the network....... >>
ROFL!
Please step away from the network sir...no, don't touch anything. step very slowly and don't make any sudden route-switch changes. We will escort you. you have the right to be pistol whipped and flogged and have your little blue box smashed right in front of you...No sir, they are not just a bunch of cabinets making "that funny wind sound", that's the gear.
please step away from the network sir.
LOL
Schoolies
funny
thanks nomeanmugs and pcmark, i know about the pools but how does the computer know to grab which pool? I know there are classes and vendor types you can specify, but is that the only way of doing it? it seems like it.
maybe i need to read more about the difference between routers and switches. my knowledge of the difference between the two so far is, routers can dish out ip addresses and share the net, and switches are faster and use mac addresses.
