Subject: I have a USB problem with a Gigabyte Z68A-D3H-B3 motherboard Back in October
royalprawn
4
Back in October or November last year, I brought my computer in to get it fixed. I also got windows 7 64-bit installed too. I had Windows Vista 32-bit installed before. Sometime after that (it could have been same day but I don't remember), my mouse (a vanilla G400) stopped working temporarily for several seconds each time. Sometimes it ended in my needing to restart my PC. It worked perfectly fine before I got Win7 installed. The guy who fixed my PC said something about needing to switch one of my PC's parts(I think my motherboard or processor) from 32-bit to 64-bithttp://forums.anandtech.com/misc.php?do=bbcode#indent
I know it's not my mouse for two reasons. The first one is that I tried using my mouse one at least one other device. The second one is that I tried using another mouse on mu PC. That makes me think it's my motherboard; especially since my front USB 3.0 port never worked. the front USB 2.0 port always has except after my mouse has been in it. After a while it does get fixed though (probably after a reboot). Downloading the software for my mouse doesn't do anything.​
I've tried several things to fix it. I've tried installing drivers including USB 3.0 drivers (which didn't fix my front USB 3.0 port). I bought a USB 3.0 expansion card, which worked, but like my back usb ports, which makes me think that my front one isn't plugged in or something. I also tried disabling the Legacy USB storage detect (or whatever it's called), but that just broke all of my back usb ports including the expansion card(which were fixed with a driver install but still have the problem). My front USB 2.0 port works fine though. I don't remember if I've updated my motherboard but I doubt I've flashed it; mostly because I'm worried about breaking it. I know my board has dual-BIOS but I'm not one to take risks. My specs: I5-2500k 3.3 GHz Gigabyte Z68A-D3H-B3 rev 1.3 GTX 570 Samsung Spinpoint 1 TB HDD 4 GB DDR3 Ram(2x2 GB)​
royalprawn
4
edit: I highly doubt it's rust(or anything similar like dust or a bad port) because it happened with my new expansion card out of the box.
redzo
547
I don't remember if I've updated my motherboard but I doubt I've flashed it; mostly because I'm worried about breaking it. I know my board has dual-BIOS but I'm not one to take risks. My specs: I5-2500k 3.3 GHz Gigabyte Z68A-D3H-B3 rev 1.3 GTX 570 Samsung Spinpoint 1 TB HDD 4 GB DDR3 Ram(2x2 GB)[/INDENT][/INDENT]
Don't be. It's a shame not giving it a try especially under this scenario when gigabyte specifies latest not beta BIOS changes for your model(F13) as "Improve USB3.0 compatibility". If you are a little careful, chances of breaking it up are very low.
Charlie98
6,298
64
...because it happened with my new expansion card out of the box.
Which USB3 expansion card did you use? I had some pretty serious problems with my Gigabyte Z68 board (cousin to yours, in sig below) and a USB3 card with VIA drivers. I wound up having to reload the OS...
There also might be an issue with the actual USB port wearing out or fatiguing... both of my rear USB3 ports (the ones I constantly plug stuff into) and, for that matter, the USB2 case port I use most.
royalprawn
4
I tried downloading and running the update, but it didn't work because it said that doesn't work with 64-bit OSes. I also tried downloading the Etron USB 3.0 Driver, but that didn't work. Maybe that's why my usb ports don't work. the problem started soon after I had windows 7 64bit installed on my PC. the timing is suspicious; especially since I've tried several things to fix it.
The Inateck KT4005 http://www.inateck.com/inateck-kt40...s-card-no-additional-power-connection-needed/ I don't think it's causing me any trouble since the motherboard usb ports have the exact same problem. that's also why I think that my motherboard's usb ports aren't wearing out since the expansion card is so new. incompatibility could explain that.
BonzaiDuck
16,833
2,155
I don't understand why you want to use your mouse with a perfectly good USB3 port. Use a USB2 port.
Check Control-Panel->Device Manager at the USB node. See if there isn't a yellow-bang ("!") indicator and/or a message that says the device is not functioning properly. It is also possible for a single port to go bad.
You could also re-install the driver. At least, find out if there are any indications in DM.
So you're going from Vista 32 to Win 7-64? See if they installed all the drivers, or if they installed any wrong drivers on the new OS.
As a parting thought, USB3 on the Z68 boards was always a tad troublesome for some. I'd had problems with it. If you choose to get a $15 to $20 USB3 PCI-E x2 controller, go into the BIOS first and turn off -- disable -- the extra-feature USB3 controller.
How did you get a VISTA-32 OS installed on a Z68 board? Was that a personal choice? Or did the computer "come to you" with it installed?
Hopefully, this is all about drivers and hardware conflicts, and the OS was basically installed properly. I am not even sure if what was probably a USB1 device would work properly on a USB3 controller. Somebody else?
Charlie98
6,298
64
What BIOS version are you running now? FWIW, I've updated the BIOS twice on my board and had nary a problem. I'm running F10, and my board is the v1.3 revision.
That PCIe card has the Renesas chipset and driver, that's the one I recommend over the VIA chipped ones... you shouldn't really have any problems. I would update the BIOS and try it again.
Ketchup
14,559
248
Have you seen a difference plugging in your mouse to the Intel ports or the Etron ports?
If you look in device manager is everything installed (no question marks, etc)?
