Sub woofer connection question
Jumpem
10,757
My powered sub I have had for a long time has L and R inputs. The receiver I purchased simply has a single plug for sub woofer output. What sort of cable do I need to make this work?
Also, are banana plugs worth the effort, or am I fine simply connecting speaker cable to the terminals on the receiver?
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
If it's just two low-level RCA inputs on the sub, just connect one of them to the receiver. Usually Left is recommended in manuals. Unless you have trouble with an auto-on feature of the sub where the signal is too weak with just the one input, then this one connection should be all you need.
I've found banana plugs to be useful since I tend to change things up fairly often to the ease of that connection type was a benefit to me, but connecting the bare speaker wire directly would work fine as well.
Jumpem
10,757
Ok, thanks for the info. :)
One more question... speaker wire... is 18G adequate, or should I order 12G?
Tiamat
14,068
how long are you running the wire? You are probably ok with 18G, I just prefer 12G. No matter what, the speaker wire is pretty inexpensive (should be around or less than 50 cents per foot).
Jumpem
10,757
Rear speaker wire would end up being ~25ft.
Tiamat
14,068
I'm sorry, I can't find the website that lists distance for gauge. If you want to be safe, 12ga is overkill and usually no more than 50 cents per foot. If you want, you can get 14ga or 16ga from home depot for ultra cheap and I am pretty sure you will be fine.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Is this the one you were thinking about, or something else?
http://www.roger-russell.com/wire/wire.htm#wiretable
Tiamat
14,068
Yes, thanks! OP, most speakers dip into the 4ohm range sometimes, so for that reason I would stick with 16 gauge at least.
