Stupid VB 6 Issue. Help.
Codewiz
5,758
Ok I have a new stupid problem. It has to do with formatting string correctly.
ATTENTION. Obviously the forum doesn't support correct formatting so the output is screwed up. Let me describe what the problem is.
The price 2.30 moves one place to the right everytime the length of item is increased BUT it should not since I am taking the length of Item into account for spacing.
FIGURED THIS OUT: Text and spaces don't take up the same amount of space. That is why the text is not staying formatted correctly. Anyone know a font where a space takes up the same area as characters?
here is what I am doing in a textbox:
txtorder.Text = txtorder.Text & "Order for " & txtName.Text & ":" & _
vbCrLf & "Item" & Space$(25) & "Price" & Space$(10) _
& "Quantity" & Space$(10) & "Cost" & vbCrLf
spaces = 25 - Len(txtItem.Text)
txtorder.Text = txtorder.Text & txtItem.Text & Space$(spaces) & txtPrice.Text & vbCrLf
I get out put like this
Order for Jon Doe:
Item Price Quantity Cost
Apples 2.30
Order for Jon Doe:
Apples2 2.30
Order for Jon Doe:
Apples23 2.30
As you see the price(2.30) keeps moving to the right even though I am supposidly using less spaces. Apples are the txtItem.text.
I can't figure out why it keeps creating extra spaces in the output eventhough I am taking into account how long the txtItem is.
The last line of code is the problem.
Help.
Jim
Codewiz
5,758
Courier New is the font that is consistent between spaces and characters.
Jim
RedFox1
587
Hmm...it looks OK to me. Obviously there's a problem...but what you've got here looks correct.
My .02
-Russ
Codewiz
5,758
Now I have another stupid problem. I am doing things with currency but I can't get it to represent $2.60. It always does $2.6.
It is really pissing me off. I am starting to realize why I never should have started VB. Give me C/C++ or Java any day of the week.
Jim
bot2600
2,075
A complex but consistant trick I use when formatting text would be to use a label with a border and put 3 text boxes or label on top of it side by side without borders and put the first column of information in the left textbox/label, and the second column of information in the second textbox/label and the third in the third. Then there is no need for spacing as everything is left justified anyhow. Hope that wasnt too confusing.
Bot
minendo
35,557
16
For the output to display in dollars like $2.60 use the below code:
Format(txtPrice.text, "$0.00")
That should fix your problem.
Codewiz
5,758
This is what I have and it still doesn't work.
cost = CCur(CDbl(txtPrice.Text) * CDbl(txtQuantity.Text))
total = total + cost
cost = Format(cost, "$0.00")
txtorder.Text = txtorder.Text & txtItem.Text & Space(19 - Len(txtItem.Text) - Len(txtPrice.Text)) & txtPrice.Text & Space(13 - Len(txtQuantity.Text)) & txtQuantity.Text & Space(9 - Len((cost))) & cost & vbCrLf
I just can't figure out what the stupid issue is.
Jim
bot2600
2,075
Try this. I made a quick project that I think does what you want. It has all the little amenities, the submit button isnt valid until all of the data is filled in and the submit button is default when you press return. Then again, I am may be totally not understanding what you are trying to do. This is the source.
Bot
Codewiz
5,758
Everything on mine works fine except the formatting of the currency. I am going to work on it some more later tonight.
Jim
bot2600
2,075
should be:
txtorder.Text = txtorder.Text & txtItem.Text & Space(19 - Len(txtItem.Text) - Len(txtPrice.Text)) & txtPrice.Text & Space(13 - Len(txtQuantity.Text)) & txtQuantity.Text & Space(9 - Len((cost))) & format(cost,"$0.00") & vbCrLf
Bot
bot2600
2,075
Or I would actually write it as
cost = Int(txtPrice) * Int(txtQuantity)
txtorder= txtorder & txtItem & Space(19 - Len(txtItem) - Len(txtPrice)) & txtPrice & Space(13 - Len(txtQuantity)) & txtQuantity & Space(9 - Len((cost))) & format(cost,"$0.00") & vbCrLf
Codewiz
5,758
Will screw up the formatting
I will try to do a space(9-Len(format(cost,"$0.00") ))
Jim
Codewiz
5,758
Bot2600,
I appreciate the help. The format fixed it once I used the Len(format(cost,"$0.00"))
Thanks again,
Jim
