stupid question, will baby-AT mobo fit in an atx case?
jkersenbr
1,691
It will fit. But the question is whether or not you will be able to get to the keyboard connector.
The back plate of the case must either be removable (which leaves a really big hole) or already have an access hole for the AT keyboard connector (unlikely in an ATX case).
A lot of ATX cases have removable back plate (I/O shiled). If so, just pop it out and your BabyAT will play quite nicely in the ATX case.
Good Luck.
awrmplace
Banned
Oct 24, 2000
57
I installed a motherboard from an aptiva which has onboard sound, video, and gameport. It also switched where the i/o ports were. The aptiva case was custom so its i/o shield wouldnt fit in the new case. After some thinking I found some hard cardboard and made my own i/o shield. It worked great. Just an idea if you run into the same problem
