After building so many PCs, you'd think I'd know the answer to this. Perhaps I've just not had a single mobo long enough before upgrading to notice when the CMOS battery dies out. How long do the lithium button batteries generally last?
Since removing the battery will clear the CMOS, and the point of the battery is to keep that from happening, is there any way to replace the battery without having to reset everything? I can't imagine doing it while the system is turned on, of course. That could fry your system if you're not careful, I'd think.
It's a shame manufacturers don't make a mobo that has two battery sockets, so you can pop a new one into the empty socket before removing the bad one, that way you don't lose your CMOS settings.
Perhaps they just figure people will upgrade as often as I do, and will never have to worry about it. An associate of mine doesn't do that, though, and has noticed her PC losing time, which is a good indication of the battery going bad, hence the question.
