Stupid question about optical cables
Replicon
152
So I am currently packing to move, and I don't have all the little plastic/rubber covers that my digital optical audio cables came in. Should I borrow some, or am I being paranoid? Are they highly recommended to prevent the tips from getting damaged? I probably don't need them, cause otherwise they'd be harder to lose, but just wondering.... thanks!
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
I think I lost mine :p
If you're worried about it, you could make covers of some kind yourself. I don't bother when I move, I just coil them up with the other ~2 million cables I take with me whenever I move.
I think one of extremely cheap optical cables has made it through 5 moves with no issues :)
PurdueRy
13,837
4
Originally posted by: Replicon
That's reassuring, thanks :). Just wanted to make sure.
If you damage it you musta been pretty rough...
Jello is right...don't worry about it
Hey jello: I am toying with the idea of what he is using an optical cable for ;)
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
:p ;)
PurdueRy
13,837
4
:p ;)
so um...OP...whatcha using that there optical cable for.....?
:shiftyeyes;
PurdueRy
13,837
4
