- Jun 12, 2001
- 8,757
- 43
- 91
UPDATE
I finally bit the bullet and used a second monitor. The reason I hesitated is because the HTPC is in a small space between the walls and it makes getting to the back of the case a pain in the butt. The small space was created when they built the house, designing the den and living room around a double chimney. There is a pocket space between the two rooms, the fireplace and a closet.
Anyway...THE SOLUTION:
1) Powered down the system
2) I connected the the second monitor through the DVI link and disconnected the HDMI link from the video card (AMD 6970)
3) Powered back up, logged into and had the second monitor running
4) Plugged the HDMI back and made the HDTV the second screen (two separate monitors not one large screen).
5) Adjusted the HDTV resolution to the proper resolution
6) Made the HDTV the primary screen, turned off the second monitor and unplugged the cables from the video card.
Took about 12-15 minutes total. The original problem was a dying battery in the bluetooth remote keyboard/mouse (http://www.logitech.com/en-us/support/dinovo-mini?osid=1&bit=32). It was giving constant key presses (Enter) making everything jitter and not useable.
THANK YOU EVERYONE FOR YOUR HEP AND ADVICE!
--------- Original Post --------------------------------------------
Stupid, stupid me. I was working on my HTPC because for some reason I was getting a lot of icon flickering and small CPU spikes. I thought it may be my fans weren't working, darware going bad, etc.
I was eliminating every possibility when I started on on the video card. I have HDMI out to A/V receiver then out to old RCA tube HDTV. I noticed the screen resolution wasn't what I thought it should be (close to 1080i but slightly smaller due to overscan issues with the TV). Anyway I reset the video to an incompatible setting, which for some reason did not revert back to the old resolution after 15 seconds (you know the one that prevents this type of crap from becoming permanent).
Does anyone know how to reset an AMD bad screen resolution? I tried RDP'ing to the system but remote sessions cannot change video.
Thanks.
Thanks.
