Stumped on math problem
Status
Not open for further replies.
cabri
3,616
Can not figure out the logic need to solve
(7^33) Modulo (10)
I can do it brute force; but have been told that is a slippery way to figure this out.
TecHNooB
7,458
Write down the 1's place for the first few powers.
7^1, 7^2, 7^3, etc. From the pattern, figure out what the 1's place of 7^33 is supposed to be. That's your answer.
dighn
22,820
4
basically you are looking for the first digit. that repeats in a pattern of 7 9 3 1, so 33 iterations gives you 4 cycles and 1, which is 7
another solution is to halve the exponent every time and also look at only the one's place:
7^33 = (7^2) ^ 16 * 7 = 49 ^ 16 * 7
take one's place only => (9^2) ^ 8 * 7 = 81^8 * 7
take one's place only => 1^8 * 7 = 7
_Rick_
3,948
70
You can pull modulo into factors.
So to make dighn's post a bit more understandable:
(7^33)mod 10 = ((7^4)mod 10)^8 * 7 mod 10, where the first term resolves to 1.
But you can also have some fun, and calculate (3^11)mod 10. This teaches you, that 3 and 7 follow the same pattern (well, inversed) for the last digit, when looking at different powers of the numbers.
disappoint
10,132
382
Where did you all learn modulo? No one ever taught me modulo or even mentioned it. Not through high school and not through an accredited BSEE degree. I only know of it after reading a book on it outside of school.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
I think the first time I ran into it was in discrete mathematics - after I had gone through 4 years of engineering & all the math that comes with it.
jaedaliu
2,670
elementary school math club? Either that or Jr. High.
I can't remember. It's been a while.
I'm pretty sure I saw it in one of my intro-to-programming courses in undergrad.
_Rick_
3,948
70
I learned to divide with a remainder in elementary school, but don't recall when I learned that there was an actual interest in it.
Got hit pretty hard with it in fresh man linear algebra, with modulo-classes and later on in a rehash in number theory, I think.
HumblePie
14,665
440
The remainder operation, Modulo, I learned pretty early. Although never really had a chance or need to apply it to a really large exponential number either. Or if I did back in the day I don't remember doing it much. I still use the operation quite a lot though as a programmer, just again not on very large exponential numbers.
Unitary
35
I know I'm a bit late, but I thought I'd share another possible solution.
Again using properties of mod, you first know that 7^2=49 is congruent to -1 (mod 10). In other words 7^2==-1 (mod 10) Take 16 powers of each side, (7^2)^16==(-1)^16 (mod 10), or (7^32)==1 (mod 10)
Multiply each side by 7 to get, 7^33==7 (mod 10)
This method avoids working with powers of 3 and uses powers of -1 instead.
JTsyo
11,976
1,099
It's used more in programming than basic math. I remember seeing it on my calculator in HS and trying to figure out what it does. I wasn't able to and had to refer to the manual.
Daverino
2,004
1*7 = 7 % 10 = 7 (7^1)
7*7 = 49 % 10 = 9 (7^2)
9*7 = 63 %10 = 3 (7^3)
3*7 = 21 % 10 = 1 (7^4)
1*7 = 7 % 10 = 7 (7^5)
Pattern repeats every at 7^4
7^33 = (7^4) ^8 *7
((7^4) ^ 8) % 10 = 1
1 * 7 = 7
Status
