Ichinisan
I work for a local cable ISP. A customer had been leasing a cable modem from us and exchanged it for one that has a built-in wireless router (about $5 extra each month).
Original model:
Newer model:
After the swap, wireless computers work perfectly fine...but the wired Windows XP desktop cannot get an IP address and shows "Limited or no connectivity."
- I walked the customer through downloading the WinsockXpFix utility from another computer. We copied it to a USB drive, ran it on the XP machine, and restarted. DHCP still fails.
- Tried Safe Mode w/ Networking. DHCP still fails.
- Tried manual IP configuration...
IP:
...and attempted to ping 192.168.0.1, but ping request times-out. Switched IP and DNS settings back to obtain automatically (DHCP).
- Customer had an older Netgear router they weren't using (I don't think it has wireless capability). Connected the computer to that router w/ no Inet connection and the computer obtained a valid IP address (192.168.1.2)!
- Connected back to the SBG941. Changed SBG941 internal IP to 192.168.1.1 and set DHCP range to 192.168.1.2+ (similar to the Netgear router). Rebooted all equipment. Still can't get an IP.
- Customer says they have tried wiring another computer directly and the wired connection works for another computer (though I can't trust that WiFi was properly disabled while testing this).
- Customer says they took the computer to a professional, who said the computer connects to the Internet just fine.
So my basic question is this:
Why would the computer be able to obtain an IP address from one router, and not another? The router appears to work fine with other computers...but there is some kind of compatibility issue here.
Original model:
- Cisco / Scientific Atlanta
- "WebStar"
- DPC2100
- DOCSIS 2.0
- No internal NAT or anything like that.
- Single RJ-45 connection
- Single USB connection
Newer model:
- Motorola
- "Surfboard"
- SBG941
- DOCSIS 2.0
- 802.11g
- Internal router does NAT and assigns local IPs
- 4x RJ-45 LAN ports
IP:
192.168.0.50
Gateway:192.168.0.1
Preferred DNS:192.168.0.1
