Ok....I went for the highest speed I can get with a 4:5 ratio versus the highest overall mhz with a 1:1 ratio....
VCORE
2.4@3.20 (4:5) 445 = 1.58v
2.4@3.24 (4:5) 450 = 1.61v
2.4@3.29 (1:1) 366 = 1.65v
2.4@3.33 (1:1) 370 = 1.70v
SANDRA: MEM
2.4@3.20 (4:5) 445 = 3418/3416
2.4@3.24 (4:5) 450 = 3438/3435 ***best***
2.4@3.29 (1:1) 366 = 2714/2710 (2,6,3,3)
2.4@3.33 (1:1) 370 = 2740/2735
3DMARK2K1SE
2.4@3.20 (4:5) 445 = 8692
2.4@3.24 (4:5) 450 = 8719
2.4@3.29 (1:1) 366 = 8698
2.4@3.33 (1:1) 370 = 8725 ***best***
BESWEET Mp3 Encoder (min/sec)
2.4@3.20 (4:5) 445 = 4min/10sec
2.4@3.24 (4:5) 450 = 4min/7sec
2.4@3.29 (1:1) 366 = 4min/3sec
2.4@3.33 (1:1) 370 = 3min/59sec ***best***
GKNOT 0.27 DIVX 5.02pro (min/sec)
2.4@3.20 (4:5) 445 = 4min/23sec
2.4@3.24 (4:5) 450 = 4min/19sec***best***
2.4@3.30 (1:1) 366 = 4min/33sec (cas 2,3,3,6)
2.4@3.30 (1:1) 366 = 4min/21sec (cas 2,2,2,5) *ran stable in this test but 3dmark would crash unless I had 2,5,3,3*
2.4@3.33 (1:1) 370 = 4min/29sec (cas 2,3,3,6)
2.4@3.33 (1:1) 370 = 4min/19sec (cas 2,2,2,5) *ran stable in this test but 3dmark would crash unless I had 2,5,3,3*
DVD2AVI (Lord of the Rings II) forced film with all tracks (min/sec)
2.4@3.24 (4:5) 450 = 3min/53sec
2.4@3.24 (1:1) 360 = 3min/55sec (2,3,3,5) **due to 2,2,2,5 not being stable
2.4@3.33 (1:1) 370 = 3min/52sec (2,2,2,5)
ReMPEG v1.52 (Lord of the Rings II VOB_5 file is reduced to 80% bitrate: same output in size and ac3)***it is being re-encoded to lower bitrate to help it fit a certain size...its benefit is getting a dual layer dvd to fit on one dvd-rw***
2.4@3.24 (4:5) 450 = 14min/18sec audio/video resynch = 1min/24sec .....file size is 217MB (orig. 262MB)(2.5,3,3,7)
2.4@3.24 (1:1) 360 = 14min/21sec audio/video resynch = 1min/48sec .....file size is 217MB (2,3,3,5)
2.4@3.33 (1:1) 370 = 14min/04sec audio/video resynch = 1min/38sec .....file size is 217MB (2,3,3,5)
Just for fun comparison
GKNOT 0.21 DIVX 3.11 (Gone in 60seconds...1hr58min...2pass, same settings)(hr/min)
1.6@2.40[i845d] (3:4) 400(cas 2.5) = 2 hr/39min
1.6@2.66[i845d] (3:4) 442(cas 2.5) = 2 hr/19min
1.6@2.73[i845d] (1:1) 342(cas 2) = 2 hr/19min
2.4@3.20[i845pe] (4:5) 445(cas 2.5) = 1 hr/58min
2.4@3.24[i845pe] (4:5) 445(cas 2.5) = 1 hr/52min
may try for 1-2 more fsb above 450ddr, but I don't think I am going to get it....lowest cas and memory timings now and had to adjust to that to get 5more mhz from 3.2ghz...
VCORE
SANDRA: MEM
3DMARK2K1SE
