Hi
I'm a student doing networking and i have a couple of problems with routers...
i have an assignment to design a network that has a connection to the internet.
i also have to set up 5 LAN's within the company that can use the internet.
all i have been told is that i can assume that i have 1 multiport router, would i connect the mutiport router to the internet connection and then daisychain the 5 LAN routers to this???
i have most of the information i need, but, i do have a couple of questions
1). what is a multiport router and how does it differ from a normal one?
can anydody answer this or point me in the direction of an answer???
2). When connecting the routers (that will connect the LAN's) with a serial cable, the serial ports need an IP address....
can these IP's be any thing i like or do they have to have a certain range????
Thank you for your time and input
Gow
Gow
