Stuck Spark Plugs
AntMan530
769
Bought some spark plugs, and other tune up stuff for my car, but when I went to finish up with the spark plugs, they were in there extremely tight. I made a couple of torques, but I was unable to remove them. My car was a little warm, not hot when i was doing this.
Any tips on removing them? I got two out, but the other two are still in there.
so i have another question...my car overheated a while back. i drove it for an unknown length of time before i pulled over and waited til it cool down then poured water and drove back home.....does that experience have any effect on my spark plugs being seized?
SampSon
7,160
Wait until the engine is bone cold and the metal is not as expanded.
Beyond that, torque hard.
AntMan530
769
i hope i didnt damage the threads....
Analog
12,755
Squirt some WD in there. How long has it been since they've been out? I usually put some anti-seize on the threads before putting them in - you may want to do this before putting the new ones in.
Make sure your socket is on the hex metal part of the plug. Sometimes going in the tightening direction a bit before trying to untighten them works to get them loose. Good luck.
0roo0roo
64,795
84
bone cold ftw. metals expand at different rates etc.. u gotta wait for it to be cold.
AntMan530
769
Theyve been in there for a good 10K. I usually change my plugs every three oil changes, so theyre about due for it. Im try the wd40 and wait.
They are super tight in there!!!
Analog
12,755
3 oil changes???? Wow, I change mine every 75,000 miles - Bosch platinums - they seem to work very well (275K on my transport minivan).
Black88GTA
3,430
Instead of WD40, try this stuff called PB Blaster. Works 10000x better than WD. Spray it around where the plug is threaded into the head. And, like others have said, wait for the car to be cold.
radioouman
8,632
How can they be that stuck at only 10k miles? I'd wait for a cold engine and then try to get them out. Also, make sure that you are on the plugs exactly straight so that you don't break one off.
Heisenberg
10,621
Yeah, every 10k is way overkill. Even lower-end plugs should last much longer than that. If the plugs are burnt or fouled after only 10k, then you have another problem.
0roo0roo
64,795
84
think my civic manual suggests 30k ..
Pepsi90919
you're nuts
Pepsi90919
you're even more nuts
AntMan530
769
haha
i need to do this...my car is scheduled for a smog...
Pepsi90919
haha
this will increase your chances exactly 0% of passing an emissions test.
AntMan530
769
haha
from my observations of the other spark plugs that i got, it looks like my car is running rich. changing the spark plugs then changing the timing will definitely help.
funboy6942
15,368
418
Key to stuck plugs is a hammer and taking it slowly. You dont want them to break off in the head or your talking mega bucks.
You get one started hitting the ratchet with a hammer and you tweek a little to get it loose and then tighten it back up. Tweek a little further and tighten it back up. And do this till it feels like it will continue to come loose without to much trouble.
This way you will be working the threads then going full force and twisting the ends off in the head. Been doing them that way for years (knock on wood) and havent had one break off yet. Infact I did the tune up on my wifes jeep today and had 2 of them stuck and that is the only way to do it. OH and the engine needs to be cold not warm or hot ;)
And also use no or the shortest extention you have. The longer the extention the less of a shock inpact from the hammer will be applied to the stuck plug. And keep that sucker straght and not cocked off to the side where you will bust the porcelen off.
And to pass emmisions find the PCV valve and remove the hose. Stick a good wad of paper in there. This is so you dont take back in the blow by from the engine. Also take out your air cleaner if it is a place that will not check to lessen the restiction of air going into the engine alowing it to breath better. Make sure to bring it there very hot so try to get it there right off the highway or go beat the crap out of the car to remove any cabon build up inside and heat it up really good. And use low octane fuel and near empty tank. The car will lean out so near empty and using less octain will allow the car to burn all the fuel. Higher octan is harder to burn so it may not burn it all up. And up the timming a smidge to the point it just wants to spark knock. Spark knock is the fuel detoning before the spark plug has a chance to light it up. You get it a chance to burn all that fuel setting the timming a little more advaced and you wont have anything come out the pipe at all ;)
0roo0roo
64,795
84
you're nuts
pretty sure it says that.
http://answers.google.com/answers/threadview?id=363590
Sundog
12,342
1/2 inch drive w/a breaker bar. Had to do this a little while ago on a F150 I sold yesterday.
CFster
1,903
Wow, just wow.
Plugs wont cure a rich condition, neither will timing.
And I hope the OP has waited until the engine cooled off before removing those plugs (especially if he has aluminum heads), as he could very easily pull the threads right out.
SampSon
7,160
you're nuts
What's so nuts about following the manual and changing standard copper plugs every 30-36K miles? Standard copper plugs arn't meant to last too much longer with peak performance.
Pepsi90919
you're nuts
uh, yeah, for severe service.
