stuck on VB program! help
piski
312
I need to read in a file that looks like this
Name Weight
Name2 Weight2
etc...
I opened the file to read from. I set up a string variable to read the name and an integer variable to read the weight but when it reads the name it also reads the weight and stores both in the string character.I guess that I need to set up an array to read the data into I just dont know where to start. Could some one give me a little advice?
sandorski
70,677
6,250
Originally posted by: sandorski
I don't know all the workings of VB, but can offer some ideas(edit: I know SFA about VB actually ;) ):
1) Put the differing data on separate lines in your data file.
2) Setup your data in a certain format. What I mean is, use a colon(or any unique character) as a terminator. For eg "Jo Schmo: 145:". You would then setup your data retrieval code to Read until the unique character.
3) Doublecheck your current code for Syntax errors, you may have simply overlooked something or have failed to use a specific form of Read.
minendo
35,560
22
csv would be much easier.
