Stuck on "POST" screen: HP Touchsmart IQ500
GoStumpy
1,211
11
Basically I push the button, and the screen comes up with the HP Logo in the center (artsy) and 4 options:
F10: Setup
Esc: Boot Menu
F9: Diagnostic
F11: System Recovery
It just sits there indefinitely.. I press F10, it says "Entering setup...", yet never does... Sits there for days....
I press Esc, it says "Entering Boot Menu..." and same thing, nothing ever happens.
If I press F9 or F11, nothing happens at all.
Completely stuck here...
My only thought is to take it apart and do a CMOS reset jumper?
What else is possible?
What could cause this?
From what I've google'd, the consensus is always hard-drive, however how can it be the hard-drive if I can't even boot from a CDROM?
Thanks for any help!!!
Here is a thread from HP's support forum that was never solved, with identical symptoms:
http://h30434.www3.hp.com/t5/TouchSmart-PC/HP-TouchSmart-IQ500-not-working/td-p/449081
GoStumpy
1,211
11
Well, apparently people were right! HDD is causing the freeze. I unplug the SATA cable to the HDD and it boots to "Insert bootable device".
Futureshop wanted $500 to fix it.. Looks like all I gotta do is reformat the HDD, or worst case scenario, replace the HDD.
postaled
254
I'm assuming you tried just plugging it back in and booting right?
I've seen probably 15-20 machines where just reseating the HDD cable fixed it.
GoStumpy
1,211
11
LOL, yeah, I plugged it back in and no-go. Tried a different SATA cable as well.
GoStumpy
1,211
11
Well, it appears like I am not alone in having this hard-drive crap out... not by a long shot:
http://h30434.www3.hp.com/t5/TouchS...el-7200-11-Seagate-Barracuda-drive/td-p/32984
Apparently a very popular bug in the Seagate 7200.11 500GB drive, especially the ones included in the Touchsmart HP's. Firmware issues cause it to brick D:
Well crap.
So I install a spare 500GB Hitachi I had laying around, and now I find the damn DVD drive doesn't work!!
So I hook up a spare DVDRW that I have laying around, and now I find that neither of my Vista OEM discs work... Windows 8 DEV works, but not Vista...
What the heck! LOL.
Downloading another Vista ISO :colbert:
