Stuck on a c++ problem, need HELP!
xchangx
I'm stuck on a problem here. Kinda long...
We're inputting from a file, one line at a time, into a character array (char input[191]).
in line there are 5 key fields and then 3 fields that repeat 10 times. I have everything setup in a struct with a few unions.
I need to setup an index for each field and would like to put it in the struct. See below...
However, I can't seem to figure out how to put the offset variable into the struct without screwing up the the initial array.
Here's the code for the struct:
struct
int byte_offset[10];
union
char input[191];
union
struct
char trans_code[2];
char emp_id[10];
char date[7];
char clk_in[6];
char clk_out[6];
struct
char qty[4];
char invent_no[7];
char dev_no[5];
}repeat[10];
}time_card;
struct
char del_trans_code[2];
char key_data[45];
char repeating[144];
}output;
}rec;
}record;
Please help!
Thanks
Michael
You have too many nested structs and unions that I can't even understand your code. I would create a single struct for each record/line that you are inputing from the file. After you do that, then you can rearange your data however it makes sense to you. Looking at your code, it's not clear exactly what you are trying to do.
struct
union
char input[191];
union
struct
char trans_code[2];
char emp_id[10];
char date[7];
char clk_in[6];
char clk_out[6];
struct
char qty[4];
char invent_no[7];
char dev_no[5];
}repeat[10];
}time_card;
struct
char key_data[45];
}output;
}rec;
}record;
Please help!
Thanks
Michael
Define structures outside the main area and then reference them internally. This is easier to read and understand. You have three primary structures. I defined them outside the acutal memory allocation area.
Now just use each structure definition as if it was an actual variable. Easier to read. Then afterwords it may be clearer to you and others to understand your problem
// Output Structure
typedef struct output_structure
char key_data[45];
// Repeat Structure
typedef struct repeated_structure
char qty[4];
char invent_no[7];
char dev_no[5];
// Timecard Structure
typedef struct timecard_structure
char trans_code[2];
char emp_id[10];
char date[7];
char clk_in[6];
char clk_out[6];
repeated_structure repeat[10];
// Record definition Structure
typedef struct record_structure
union
timecard_structure time_card;
output_structure output;
} rec;
// Processing Record
struct
union
char input[191];
record_structure rec;
}record;
