mvbighead
Well guys, looking for comments on how to proceed...
I have a 52" Exmark Turf Tracer that has been a very good mower for me, and I had sharpened the blades earlier this season with no problem. This time around, I need to resharpen them because I, like an idiot, ran over something fairly solid that got picked up and whacked the blades good.
I sharpened two blade with no issue at all. The third blade simply will not come off as the bolt is stuck.
I've tried heat and penetrating oil, and I have a new impact wrench (http://www.harborfreight.com/12-in-professional-air-impact-wrench-68424.html) that seems to have a bit more oomph (~700 compared to 220 ft lbs) than my Craftsman C3 19.2v cordless (which is generally sufficient for most things). I have also tried a breaker bar plus cheater pipe (but sadly only had a piece of copper pipe which seems to flex too much). I have purchased a new 60" section of steel pipe to be used as my new cheater pipe, but have yet to attempt in hopes that I can do something that hopefully won't destroy the spindle.
Purchased some "freezing" compound that is said to free "rusted" bolts, but I fear that rust is not the problem that I am dealing with. I was thinking that heat causes expansion, so if I can get it good and cold, that should cause contraction, and perhaps that would give me a chance? Is supposedly a freezing lubricating compound (something like http://www.amazon.com/Finish-Line-Fr...zing+lubricant).
I am still thinking about how I should do this. If I break the spindle, I'd be out roughly $100 to buy a new one on ebay or something. I've read (after already attempting this) that heat may not be the best thing to use near the spindle. I'm at a loss. My only other option is to borrow a trailer and drag it to a mechanic with a better quality impact and hope that their stuff can break it free, but the trouble there lies in driving 30 mile round trip to go get a trailer, and 30 miles round trip to return it.
As it is, the mower is working fine, but that particular blade is simply stuck on there tighter than I can seem to get to move. And since it flexes and tried so turn, I fear that is taking away some of my leverage. Any pointers?
TLDR: Blade on super tight, has been removed a few months ago so it shouldn't be rusted. Impact and other tools seem to be of no use.
