Stuck in Morrowind-please help
tboo
7,626
Im trying to complete the final Fighters Guild Quest where I have to kill the Master Thief in the bookshop. Only problem is he is behind a locked door-a 65pt locked door. I have some magical items that unlock, but only up to 60pts. What do i do?
Thanks
stryder2929
324
ahh their is a spell the next level up that will do it,
i believe its called echash locksplitter or something
sthe spelling is def. wrong but it begins with an e and ends with locksplitter :)
anyway, try vivec, u'll find it there
misle
3,371
Is that the quest where they send you to kill off all the Thieves Guild Masters? If so, don't do it. Go talk to the Fighter Guild master at Ald-ruhn. He will tell you not to do it. You then can go kill the Fighter's Guild master and take his place.
tboo
7,626
Yeah, misle thats it. I already did it the other way & saved it as a seperate game I am now trying it this way. I already killed the bosses & now am trying to get the master thief. stryder2929, thanks for the info-ill look into that. i also found out I can have an item enchanted to open locks-I need to get a soul gem & a soul trap spell & find me a victim!
misle
3,371
If you want to spend some money, you can go to Hecerinde (In Hecerinde's House) in Balmora and train to be able to pick the lock. At Security level 20-30, you should be able to pick a 65 lock without a problem.
