will a sunbeam rheobus be able to power on each channel a Delta FFB1212VHE http://www.sidewindercomputers.com/de12ff.html
it comes with a 3pin and 4 pin connector attached directly to the motor.
Specs from Sidewinder Computers
120x120x38mm, 151.85 CFM @ 3200 RPM, 53.0 dBA, 12.00 watts, 1.00 amps, 12v DC, 3+4 pin Molex connectors.
i bolded the "1.00 amps" because on the fan label, its labeled 1.5a.
i've already tried connecting this fan with the 3pin to my motherboard, doesn't power up.
tried connecting this fan to power supply with a Zalman Fanmate 2, doesn't power up.
only luck with powering it on is via the 4pin and power supply.
