I recently got a WRT54G router (ver. 3) and then flashed it to dd-wrt. No I'm not sure if this is because of an antenna problem so if it may not, please suggest an alternative. Buying a stronger antenna is pretty much the last option I want to do. I want to try everything to get that signal stronger.
Right now, Windows says I have 2 bars and it's at 36MB. I want that a little higher. DD-WRT says that I'm only at 18%. And my speed is severely impaired because of this. I have DSL and the router is cause my download speed to be ~300kB/s. Now thats no were near my max of 3mb/s (yes the b's are correct, capital and lowercase). When the computer is plugged directly into the router, I get 600+kB/s download speed.
Also, if I recall right when I got the router that with the standard firmware the speed was faster, but this was when the router was at a different place and when I had cable internet.
Now my house has several computers but the problem is that most of them get a really low signal and the transfer rate isn't all that great because of this.
I'm wondering if I can get a stronger antenna to attatch to the router. The router isn't connected by a wire to any computer (the place were the dsl connection is is far away from any computer) so I just plugged it in, set it up, then plugged it in were the dsl connection is.
Problem with this is that both computers in the house are pretty far away (not that far but a lot of junk is inbetween) and the signal is almost always on low and also it says it's connected with 18 MB while it's a wireless-G connection so it should be 54MB (i think thats because of the bad connection).
I've already tried boosted the xmit power with dd-wrt to the recommended max of 70 but no luck. Signal is the same.
I have no idea about external antenna's, I know a lot about other parts in computers but networking is not my strong point. So maby a recommendation or a guide would also help a lot.
Thanks
Thanks
