Strip voice from an audio track?
thestrangebrew1
4,104
779
Not sure if I should post this here or in Audio, but basically I'm looking for a program to strip voice from an audio track so I can just listen to the beat. I'm looking for something free, not really wanting to drop coin for 1 song.
Gooberlx2
15,381
I'm no audio expert, but I'm going to guess that's not possible unless the voice is literally a second track within the file. If it is possible, it's going to take some advanced tools that aren't free.
In any case, Audacity is the best free audio editor I know of. At best you might be able to filter out a range of frequencies, targeting the voice. You'll likely strip away some of the beat as well though - unless there's actually no crossover, which I find unlikely.
There's this tutorial, but it hasn't worked all that well on the tracks I've tried. Or rather, I don't like how it pretty substantially changes the way the music sounds. You lose stereo separation, you lose bass, it sounds noisy and confusing, and you can still hear the vocals slightly. Maybe it works better on some tracks than others.
thestrangebrew1
4,104
779
http://lifehacker.com/296121/remove-vocals-from-mp3s-with-audacity
Awesome thanks for the tip I'll check it out tonight!
sm625
8,172
137
I've tried audacity's voice removal feature. It attenuates but does not completely remove voices. What you can do is zoom down into the waveform and manually clip out the vocal frequencies. It would take some time, but with the right amount of cuttin, pasting, and erasing you could completely eliminate all voices.
