Strip/stuck lug nut
SAWYER
16,742
42
I have a stuck/strip luck nut and the lug nut stud is also spinning, how should I get this off? I do not have a cutting torch or a drill but I can go by a drill if needed.
SAWYER
16,742
42
I dont have a compressor or impact wrench. What psi/hp compressor would be good enough to run an impact wrench?
jlee
48,518
223
If the stud is spinning; how is an impact wrench going to help? :confused:
Depends how badly it's spinning - if it's just barely spinning under a lot of force, an impact might knock it free. If it spins easily, then it likely won't do anything.
herm0016
8,518
1,128
best bet is probably to drill it out, or if you have access get a dremel or grinder to cut it off.
SAWYER
16,742
42
I have a grinder and the stock pad that came with it I havent used, not sure if it will work on metal. I think it might be a little big to use efficiently in the space though. I can not drive because the lug nut is backed off and it is actually two that are spinning and stuck
jlee
48,518
223
4 or 5 lug wheels? If they're 5 lug, I would consider limping it to a shop on 3 (properly torqued - do not overtighten to compensate for the loose ones).
How far backed off are they? I'm wondering if there's enough room on the back of the hub to cut/grind the backing for the stud off, but there's probably not enough room.
monkeydelmagico
3,961
145
Try to get at least one tightened otherwise it's time for the tow truck. I get the impression you don't have alot of tools or skills.
olds
50,125
779
Take the hub off with the wheel still mounted. Grind off the back of the offending stud. Put in new stud.
bruceb
8,874
111
Can you get to the back of the stud ? ? If you can get a welder to just quick tack it in place, remove the nut and then replace the offending stud.
Ramses
2,871
4
Dremel with the reinforced fibre cutoff wheel. Buy five or six, wear safety glasses.
If you don't have welder and don't want to pull hub off.
Slit the nut till it falls off or if there is room just cut the stud off.
Take 20 min tops.
Use anti-sieze next time. :)
