- Oct 16, 1999
- 10,490
- 4
- 0
Update: About two months ago I started having nightly DSL outages starting after dusk and continuing until I went to bed, with an occasional one or two during the day. The DSL connection light on the modem would stay on, but no throughput. Resetting the modem or DSL line would fix it until it happened again. Did the usual rigmarole swapping cables, filters, routers, modems, outlets, etc. with no fix. Called teleco, jumped through all their hoops until they said they'd send someone to physically look at my line. Never got a followup after that, and the outages still occurred. Started looking into RFI sources, thought I had one potential culprit one floor below. CFL on motion sensor switch (installed years ago). Cut breaker to switch, nightly outages still occurred. Looked at flickering street lamp (though it had been that way for years), figured that was culprit, called power co, they fixed it yesterday morning.
Last night my DSL goes down again around the time street light came on. Reset the line, DSL stayed up for several hours later until I went to bed. I wake up this morning and my DSL is down again. I chalk it up to either street light going off or a brownout that night. I reset modem and the DSL is back up. I turn on breaker to CFL downstairs and notice the DSL goes down. I confirm that the CFL is ALSO causing my DSL to drop when turned on. I pull the motion detector switch and install a normal one, and it still kills my DSL when switched on. I leave the house with a turned off CFL and then-working DSL line. I get back home, DSL is down gain. I get the phone to listen for line noise when the CFL is turned on and off. No noise from the CFL being switched on, but there is faint random popping on the phone line. Go outside to the phone box, pull the house wires and hook a phone in directly and the popping is still there. So I'm at a loss now as to just WTF is going on.
tl;dnr
1. DSL goes down multiple times nightly, modem/line reset restores throughput
2. Outages also coincide with street lamp cycling and flickering (about 50 ft. away)
3. CFL downstairs kills DSL when switched on, but tripping breaker does not prevent additional outages
4. Faint but definite static on phone line, present at junction box with house lines unplugged
Original post: Should I call the phone company or power company about it? The light has been flickering and causing nightly outages for a couple of months before I figured out what was going on. They came today and fixed the light so it doesn't flicker, but it still killed my internet when it popped on tonight.
tl;dnr
