Stream video signal over LAN
nusyo
What I need: Stream CCTV cameras (it has RCA, VGA and HDMI outpus) over network using DLNA so I can see it on smartTVs or receivers (etc.) that support DLNA.
Since hdhomerun can stream tv channels using DLNA, I figured there should be a box that can take any video input and stream it, right? ...
I was also thinking to use a raspberry pi and turn it into a dlna server, but how do you get the signal in?
  • I was reading somewhere else broadcasting over the same RGB cables on diff.frequencies, but I really don't wanna do that since wifi/cat5e is available
  • Also I don't want to have a pc on all the time with a capture card
