Strange USB Memorystick problem
eschk
Hi!
I just bought 2 SuperTalent PICO gold 8gb that i am going to use in my pioneer cdj-400:s to have music on when I DJ. The problem is that it's only one of them that works in the cdj-400 players (i have tried to change usb between the players). They both work properly in the computer, write, read etc.
The differens that i can see is that the one that works is named USB DRIVE on "My Computer" and the other one is called Removable Disk.
Now, when i check the device manager the one that works properly in the cdj-400:s is called "Flash Drive SM_USB20 USB Device" and the one that doesn't work is called "Ut165 USB2FlashStorage USB Device".
I have tried uninstalled the "broken" one and install again but it doesn't help. I have also formatted the drive. Shouldn't both usb drives be called "Flash Drive SM_USB20 USB Device" because the drives are identical?
//Erik
