- Apr 27, 2021
- 3
- 1
- 36
I have a used HP ProBook 655 G1.
I noticed at times when it gets busy (like I start a game or something). The fan Revs up eventually all the way after only like 30 seconds.
The strange part is this:
Air DOES come out the vent, but it is cool air UNTIL I hear something actuate inside. Like a short "pfft-click" and SUDDENLY the air from the exhaust goes from cool to hot. A few seconds after this happens the fan calms down and everything continues as normal.
There have been a couple times that the "click" sound didn't happen quick enough and it shut down (im guessing from thermal protection).
However, If I DO hear the "click" then I can use the system indefinitely without issue.
I opened it up and applied some new thermal grease to the apu just to be safe. I also ensure none of the intakes are blocked.
The heat-spreader has good contact (best that I can tell anyway). The fan is working, and since it spins faster as the temp goes up I'm guessing the thermal sensors are working properly as well...yes??? There simply seems to be no heat transfer to the exhaust until I hear that little sound.
Any insight into what is happening would be greatly appreciated.
