Strange System and CPU Temperature detected by SiSoftware Sandra.
dodo
317
I have ECS K7S5A motherboard and AMD XP1800+. I use SiSoftware Sandra to get the motherboard infor. It shows Board Temp 5C, CPU 32C, Power/Aux Temp 49C. I thought System temp 32C and CPU temp 49C sound more reasonable. What maybe wrong here? Did I connect some wire to the wrong place?
Thanks a lot.
dodo
Reliant
3,843
Sandra could be reporting it wrong....
You can check your temps in the bios and see how they matchup to the Sandra temps...Sandra may be mixing two sensors.
dodo
317
I will check it when I went back to home. I also installed VCool a software to cool CPU. It reads CPU 5C and System 32C! I think there much be something wrong here. Any other comments?
Thanks a lot.
dodo
