Here's the specs:
Asus A7M266 (latest bios)
AMD Athlon Thunderbird 1.2ghz
Visiontek GeForce3 Ti200 (29.42 Detonators)
256MB Crucial DDR SDRAM
300W Power Supply
60GB IBM HD
Windows XP Professional
Basically, my computer crashes when playing Warcraft III. It's entirely random how soon into the game it will happen, but it tends to crash faster in multiplayer. It's only happened in Warcraft III, not in other applications or other games (Tribes 2, Half-Life, Jedi Knight 2)
When it crashes, it isn't a lock-up or BSOD - it's a beep and a hard reboot. And it's not XP's "Ooh, I'll reboot to avoid a blue screen!" feature, I turned that off long ago, and I've double-checked to make sure it was still off.
The sudden reboot lends me to believe it'd be a hardware problem, but I can't figure out why it would ONLY happen in Warcraft. My computer appears perfectly stable otherwise.
I've checked temperature. It took me far too long to think of this, but I checked it and it was a little higher than I'd have liked, but nothing to cause crashes. Reapplied the heatsink anyway, my CPU is now 46C, and the case is 24C (pretty much room temperature). I've tabbed out of WC3 to check temperature, and loaded up MBM immediately after a crash, and the highest I've seen is 51C.
Tried a couple video card drivers, and toned down the graphics settings, and that did nothing. I've also run Sandra (burn-in tests) to see if I can find a problem outside of WC3, and nothing happened...tests on the processor and RAM, mostly.
So, anyone have any ideas what may be wrong? Or is probably just a problem with the game that leaves me SOL?
300W Power Supply
60GB IBM HD
