I recently noticed that my pc is having some probs with ram. I have 1 stick of samsung 512 pc2700 ddr333 ram in my asus a7n8x deluxe mobo . when i look at system properties or dxdiag it always tells me i have 256mb of ram, wtf. i have taken it out and blown air on it, blown air in the slot, put it in a different slot and tried to boot (nothing happend). does anybody know what could be wrong?
i also noticed in the display tab of dxdiag , under "approx. total memory" it says 128mb this is troubling because i have a gainward geforce fx 5900 ultra 256mb ram.
i looked in the bios and messed with a few settings but nothing seems to work. it almost seems like my pc is telling my ram to cut itself in half.
here is my dxdiag log:
System Information
Time of this report: 8/6/2003, 06:36:31
Machine name: MAIN
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 1 (2600.xpsp2.030422-1633)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK Computer INC.
System Model: A7N8X
BIOS: Ver 1.65
Processor: AMD Athlon(tm) XP 2400+, MMX, 3DNow, ~2.0GHz
Memory: 256MB RAM
Page File: 157MB used, 845MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce FX 5900 Ultra
Manufacturer: NVIDIA
Chip type: GeForce FX 5900 Ultra
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0330&SUBSYS_0A0010B0&REV_A1
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: SyncMaster 172T/176T SyncMaster Magic CX176T/CX171T(Digital)
Monitor Max Res: 1280,1024
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.4403 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 5/2/2003 03:19:00, 3180171 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/2/2003 03:19:00, 1312555 bytes
Device Identifier: {D7B71E3E-4070-11CF-3362-0A2A00C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0330
SubSys ID: 0x0A0010B0
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: NVIDIA(R) nForce(TM) Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: *NFORCE
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvapu.sys
Driver Version: 5.10.2917.0000 (English)
WHQL Logo'd: Yes
Date and Size: 12/5/2002 12:01:00, 241664 bytes
Other Files:
Driver Provider: NVIDIA Corporation
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 255, 252
Static/Strm HW 3D Bufs: 64, 64
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: NVIDIA(R) Kernel Synthesizer, Hardware (Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
NVIDIA(R) nForce(TM) Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
NVIDIA(R) DLS Synthesizer [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: AxisPad
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x05FD, 0x3002
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x0067
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/29/2002 12:00:00, 51968 bytes
| Driver: usbd.sys, 8/29/2002 12:00:00, 4736 bytes
+-+ USB Human Interface Device
| | Service: HidUsb
| | OEMData: 03 00 08 10 14 00 00 00
| | Flags 2: 15020000
| | Driver: hidusb.sys, 8/17/2001 14:02:20, 9600 bytes
| | Driver: hidparse.sys, 8/17/2001 14:02:08, 23680 bytes
| | Driver: hid.dll, 8/29/2002 12:00:00, 22528 bytes
| | Driver: hidclass.sys, 8/29/2002 01:32:42, 34560 bytes
| +-+ HID-compliant game controller
| | | Matching Device ID: hid_device_system_game
| | | Flags 2: 15020000
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/29/2002 12:00:00, 62976 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/29/2002 01:32:44, 9856 bytes
PS/2 Devices
+ Easy Internet Keyboard
| Matching Device ID: *pnp0303
| Upper Filters: ITCHFLTR
| Service: i8042prt
| Driver: i8042prt.sys, 8/29/2002 02:06:38, 51072 bytes
| Driver: kbdclass.sys, 8/29/2002 01:27:02, 23424 bytes
| Driver: itchfltr.sys, 11/15/2002 02:15:00, 12640 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/29/2002 03:46:42, 38024 bytes
+ HID-compliant MX300 Optical Mouse
| Vendor/Product ID: 0x046D, 0xC024
| Matching Device ID: hid\vid_046d&pid_c024
| Upper Filters: LMouFlt2
| Lower Filters: LHidFlt2
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
| Driver: mouclass.sys, 8/29/2002 01:27:02, 22016 bytes
| Driver: LHidFlt2.Sys, 6/30/2003 09:50:00, 25214 bytes
| Driver: LMouFlt2.Sys, 6/30/2003 09:50:00, 72894 bytes
| Driver: Logi_MwX.Exe, 6/30/2003 09:50:00, 19968 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Star Wars JK II Jedi Outcast (DX7) - Registry: OK, ExeFile: jk2mp.exe ()
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 3.1 GB
Total Space: 15.0 GB
File System: FAT32
Model: ST360021 A SCSI Disk Device
Drive: D:
Free Space: 5.1 GB
Total Space: 31.0 GB
File System: FAT32
Drive: E:
Free Space: 2.0 GB
Total Space: 11.2 GB
File System: FAT32
Drive: I:
Free Space: 57.3 GB
Total Space: 76.3 GB
File System: NTFS
Model: WDC WD80 0JB-00FSA0 SCSI Disk Device
Drive: G:
Model: JLMS DVD-ROM LTD-166S SCSI CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.1106 (English), 8/29/2002 12:00:00, 47488 bytes
Drive: H:
Model: SAMSUNG CD-R/RW SW-232B SCSI CdRom Device
System Devices
Name: NVIDIA GeForce FX 5900 Ultra
Device ID: PCI\VEN_10DE&DEV_0330&SUBSYS_0A0010B0&REV_A1\4&1B197270&0&00F0
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 1312555 bytes
Driver: C:\WINDOWS\System32\nvinstnt.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 126976 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 69632 bytes
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 3180171 bytes
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 3764224 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 4640768 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 49152 bytes
Driver: C:\WINDOWS\System32\nview.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 835654 bytes
Driver: C:\WINDOWS\System32\dmcpl.exe, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 1323008 bytes
Driver: C:\WINDOWS\System32\nvshell.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 467016 bytes
Driver: C:\WINDOWS\System32\nvtuicpl.cpl, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 143360 bytes
Driver: C:\WINDOWS\System32\nwiz.exe, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 323584 bytes
Driver: C:\WINDOWS\System32\nviewimg.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 512000 bytes
Driver: C:\WINDOWS\System32\keystone.exe, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 286806 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 5/2/2003 03:19:00, 50792 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 5/2/2003 03:19:00, 22977 bytes
Driver: C:\WINDOWS\nview\generic.tvp, 5/2/2003 03:19:00, 30902 bytes
Driver: C:\WINDOWS\System32\nvrsar.dll, 6.14.0010.4403 (Arabic), 5/2/2003 03:19:00, 3403776 bytes
Driver: C:\WINDOWS\System32\nvwrsar.dll, 6.14.0010.4403 (Arabic), 5/2/2003 03:19:00, 143360 bytes
Driver: C:\WINDOWS\System32\nvrscs.dll, 6.14.0010.4403 (Czech), 5/2/2003 03:19:00, 249856 bytes
Driver: C:\WINDOWS\System32\nvwrscs.dll, 6.14.0010.4403 (Czech), 5/2/2003 03:19:00, 159744 bytes
Driver: C:\WINDOWS\System32\nvrsda.dll, 6.14.0010.4403 (Danish), 5/2/2003 03:19:00, 258048 bytes
Driver: C:\WINDOWS\System32\nvwrsda.dll, 6.14.0010.4403 (Danish), 5/2/2003 03:19:00, 159744 bytes
Driver: C:\WINDOWS\System32\nvrsde.dll, 6.14.0010.4403 (German), 5/2/2003 03:19:00, 266240 bytes
Driver: C:\WINDOWS\System32\nvwrsde.dll, 6.14.0010.4403 (German), 5/2/2003 03:19:00, 176128 bytes
Driver: C:\WINDOWS\System32\nvrsel.dll, 6.14.0010.4403 (Greek), 5/2/2003 03:19:00, 253952 bytes
Driver: C:\WINDOWS\System32\nvwrsel.dll, 6.14.0010.4403 (Greek), 5/2/2003 03:19:00, 184320 bytes
Driver: C:\WINDOWS\System32\nvrseng.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 258048 bytes
Driver: C:\WINDOWS\System32\nvwrseng.dll, 6.14.0010.4403 (English), 5/2/2003 03:19:00, 147456 bytes
Driver: C:\WINDOWS\System32\nvrses.dll, 6.14.0010.4403 (Spanish), 5/2/2003 03:19:00, 258048 bytes
Driver: C:\WINDOWS\System32\nvwrses.dll, 6.14.0010.4403 (Spanish), 5/2/2003 03:19:00, 176128 bytes
Driver: C:\WINDOWS\System32\nvrsesm.dll, 6.14.0010.4403 (Spanish), 5/2/2003 03:19:00, 282624 bytes
Driver: C:\WINDOWS\System32\nvwrsesm.dll, 6.14.0010.4403 (Spanish), 5/2/2003 03:19:00, 147456 bytes
Driver: C:\WINDOWS\System32\nvrsfi.dll, 6.14.0010.4403 (Finnish), 5/2/2003 03:19:00, 249856 bytes
Driver: C:\WINDOWS\System32\nvwrsfi.dll, 6.14.0010.4403 (Finnish), 5/2/2003 03:19:00, 163840 bytes
Driver: C:\WINDOWS\System32\nvrsfr.dll, 6.14.0010.4403 (French), 5/2/2003 03:19:00, 266240 bytes
Driver: C:\WINDOWS\System32\nvwrsfr.dll, 6.14.0010.4403 (French), 5/2/2003 03:19:00, 172032 bytes
Driver: C:\WINDOWS\System32\nvrshe.dll, 6.14.0010.4403 (Hebrew), 5/2/2003 03:19:00, 3391488 bytes
Driver: C:\WINDOWS\System32\nvwrshe.dll, 6.14.0010.4403 (Hebrew), 5/2/2003 03:19:00, 139264 bytes
Driver: C:\WINDOWS\System32\nvrshu.dll, 6.14.0010.4403 (Hungarian), 5/2/2003 03:19:00, 245760 bytes
Driver: C:\WINDOWS\System32\nvwrshu.dll, 6.14.0010.4403 (Hungarian), 5/2/2003 03:19:00, 167936 bytes
Driver: C:\WINDOWS\System32\nvrsit.dll, 6.14.0010.4403 (Italian), 5/2/2003 03:19:00, 270336 bytes
Driver: C:\WINDOWS\System32\nvwrsit.dll, 6.14.0010.4403 (Italian), 5/2/2003 03:19:00, 172032 bytes
Driver: C:\WINDOWS\System32\nvrsja.dll, 6.14.0010.4403 (Japanese), 5/2/2003 03:19:00, 3387392 bytes
Driver: C:\WINDOWS\System32\nvwrsja.dll, 6.14.0010.4403 (Japanese), 5/2/2003 03:19:00, 106496 bytes
Driver: C:\WINDOWS\System32\nvrsko.dll, 6.14.0010.4403 (Korean), 5/2/2003 03:19:00, 3383296 bytes
Driver: C:\WINDOWS\System32\nvwrsko.dll, 6.14.0010.4403 (Korean), 5/2/2003 03:19:00, 102400 bytes
Driver: C:\WINDOWS\System32\nvrsnl.dll, 6.14.0010.4403 (Dutch), 5/2/2003 03:19:00, 262144 bytes
Driver: C:\WINDOWS\System32\nvwrsnl.dll, 6.14.0010.4403 (Dutch), 5/2/2003 03:19:00, 167936 bytes
Driver: C:\WINDOWS\System32\nvrsno.dll, 6.14.0010.4403 (Norwegian (Bokmål)), 5/2/2003 03:19:00, 258048 bytes
Driver: C:\WINDOWS\System32\nvwrsno.dll, 6.14.0010.4403 (Norwegian (Bokmål)), 5/2/2003 03:19:00, 159744 bytes
Driver: C:\WINDOWS\System32\nvrspl.dll, 6.14.0010.4403 (Polish), 5/2/2003 03:19:00, 245760 bytes
Driver: C:\WINDOWS\System32\nvwrspl.dll, 6.14.0010.4403 (Polish), 5/2/2003 03:19:00, 163840 bytes
Driver: C:\WINDOWS\System32\nvrspt.dll, 6.14.0010.4403 (Portuguese), 5/2/2003 03:19:00, 249856 bytes
Driver: C:\WINDOWS\System32\nvwrspt.dll, 6.14.0010.4403 (Portuguese), 5/2/2003 03:19:00, 176128 bytes
Driver: C:\WINDOWS\System32\nvrsptb.dll, 6.14.0010.4403 (Portuguese), 5/2/2003 03:19:00, 266240 bytes
Driver: C:\WINDOWS\System32\nvwrsptb.dll, 6.14.0010.4403 (Portuguese), 5/2/2003 03:19:00, 172032 bytes
Driver: C:\WINDOWS\System32\nvrsru.dll, 6.14.0010.4403 (Russian), 5/2/2003 03:19:00, 262144 bytes
Driver: C:\WINDOWS\System32\nvwrsru.dll, 6.14.0010.4403 (Russian), 5/2/2003 03:19:00, 176128 bytes
Driver: C:\WINDOWS\System32\nvrssk.dll, 6.14.0010.4403 (Slovak), 5/2/2003 03:19:00, 245760 bytes
Driver: C:\WINDOWS\System32\nvwrssk.dll, 6.14.0010.4403 (Slovak), 5/2/2003 03:19:00, 167936 bytes
Driver: C:\WINDOWS\System32\nvrssl.dll, 6.14.0010.4403 (Slovenian), 5/2/2003 03:19:00, 253952 bytes
Driver: C:\WINDOWS\System32\nvwrssl.dll, 6.14.0010.4403 (Slovenian), 5/2/2003 03:19:00, 155648 bytes
Driver: C:\WINDOWS\System32\nvrssv.dll, 6.14.0010.4403 (Swedish), 5/2/2003 03:19:00, 258048 bytes
Driver: C:\WINDOWS\System32\nvwrssv.dll, 6.14.0010.4403 (Swedish), 5/2/2003 03:19:00, 159744 bytes
Driver: C:\WINDOWS\System32\nvrstr.dll, 6.14.0010.4403 (Turkish), 5/2/2003 03:19:00, 262144 bytes
Driver: C:\WINDOWS\System32\nvwrstr.dll, 6.14.0010.4403 (Turkish), 5/2/2003 03:19:00, 163840 bytes
Driver: C:\WINDOWS\System32\nvrszhc.dll, 6.14.0010.4403 (Chinese), 5/2/2003 03:19:00, 217088 bytes
Driver: C:\WINDOWS\System32\nvwrszhc.dll, 6.14.0010.4403 (Chinese), 5/2/2003 03:19:00, 86016 bytes
Driver: C:\WINDOWS\System32\nvrszht.dll, 6.14.0010.4403 (Chinese), 5/2/2003 03:19:00, 217088 bytes
Driver: C:\WINDOWS\System32\nvwrszht.dll, 6.14.0010.4403 (Chinese), 5/2/2003 03:19:00, 86016 bytes
Driver: C:\WINDOWS\help\nvcpar.hlp, 5/2/2003 03:19:00, 77671 bytes
Driver: C:\WINDOWS\help\nvwcpar.hlp, 5/2/2003 03:19:00, 22833 bytes
Driver: C:\WINDOWS\help\nvcpcs.hlp, 5/2/2003 03:19:00, 85508 bytes
Driver: C:\WINDOWS\help\nvwcpcs.hlp, 5/2/2003 03:19:00, 24777 bytes
Driver: C:\WINDOWS\help\nvcpda.hlp, 5/2/2003 03:19:00, 54358 bytes
Driver: C:\WINDOWS\help\nvwcpda.hlp, 5/2/2003 03:19:00, 23275 bytes
Driver: C:\WINDOWS\help\nvcpde.hlp, 5/2/2003 03:19:00, 56415 bytes
Driver: C:\WINDOWS\help\nvwcpde.hlp, 5/2/2003 03:19:00, 24155 bytes
Driver: C:\WINDOWS\help\nvcpel.hlp, 5/2/2003 03:19:00, 96427 bytes
Driver: C:\WINDOWS\help\nvwcpel.hlp, 5/2/2003 03:19:00, 24017 bytes
Driver: C:\WINDOWS\help\nvcpeng.hlp, 5/2/2003 03:19:00, 50690 bytes
Driver: C:\WINDOWS\help\nvwcpeng.hlp, 5/2/2003 03:19:00, 20453 bytes
Driver: C:\WINDOWS\help\nvcpes.hlp, 5/2/2003 03:19:00, 52949 bytes
Driver: C:\WINDOWS\help\nvwcpes.hlp, 5/2/2003 03:19:00, 21880 bytes
Driver: C:\WINDOWS\help\nvcpesm.hlp, 5/2/2003 03:19:00, 53497 bytes
Driver: C:\WINDOWS\help\nvwcpesm.hlp, 5/2/2003 03:19:00, 21907 bytes
Driver: C:\WINDOWS\help\nvcpfi.hlp, 5/2/2003 03:19:00, 55946 bytes
Driver: C:\WINDOWS\help\nvwcpfi.hlp, 5/2/2003 03:19:00, 23322 bytes
Driver: C:\WINDOWS\help\nvcpfr.hlp, 5/2/2003 03:19:00, 54995 bytes
Driver: C:\WINDOWS\help\nvwcpfr.hlp, 5/2/2003 03:19:00, 23262 bytes
Driver: C:\WINDOWS\help\nvcphe.hlp, 5/2/2003 03:19:00, 78982 bytes
Driver: C:\WINDOWS\help\nvwcphe.hlp, 5/2/2003 03:19:00, 23449 bytes
Driver: C:\WINDOWS\help\nvcphu.hlp, 5/2/2003 03:19:00, 58809 bytes
Driver: C:\WINDOWS\help\nvwcphu.hlp, 5/2/2003 03:19:00, 26819 bytes
Driver: C:\WINDOWS\help\nvcpit.hlp, 5/2/2003 03:19:00, 53182 bytes
Driver: C:\WINDOWS\help\nvwcpit.hlp, 5/2/2003 03:19:00, 23297 bytes
Driver: C:\WINDOWS\help\nvcpja.hlp, 5/2/2003 03:19:00, 80143 bytes
Driver: C:\WINDOWS\help\nvwcpja.hlp, 5/2/2003 03:19:00, 32944 bytes
Driver: C:\WINDOWS\help\nvcpko.hlp, 5/2/2003 03:19:00, 87057 bytes
Driver: C:\WINDOWS\help\nvwcpko.hlp, 5/2/2003 03:19:00, 33084 bytes
Driver: C:\WINDOWS\help\nvcpnl.hlp, 5/2/2003 03:19:00, 53770 bytes
Driver: C:\WINDOWS\help\nvwcpnl.hlp, 5/2/2003 03:19:00, 23097 bytes
Driver: C:\WINDOWS\help\nvcpno.hlp, 5/2/2003 03:19:00, 54358 bytes
Driver: C:\WINDOWS\help\nvwcpno.hlp, 5/2/2003 03:19:00, 22919 bytes
Driver: C:\WINDOWS\help\nvcppl.hlp, 5/2/2003 03:19:00, 57780 bytes
Driver: C:\WINDOWS\help\nvwcppl.hlp, 5/2/2003 03:19:00, 23937 bytes
Driver: C:\WINDOWS\help\nvcppt.hlp, 5/2/2003 03:19:00, 53072 bytes
Driver: C:\WINDOWS\help\nvwcppt.hlp, 5/2/2003 03:19:00, 23662 bytes
Driver: C:\WINDOWS\help\nvcpptb.hlp, 5/2/2003 03:19:00, 53767 bytes
Driver: C:\WINDOWS\help\nvwcpptb.hlp, 5/2/2003 03:19:00, 23494 bytes
Driver: C:\WINDOWS\help\nvcpru.hlp, 5/2/2003 03:19:00, 57406 bytes
Driver: C:\WINDOWS\help\nvwcpru.hlp, 5/2/2003 03:19:00, 24149 bytes
Driver: C:\WINDOWS\help\nvcpsk.hlp, 5/2/2003 03:19:00, 86673 bytes
Driver: C:\WINDOWS\help\nvwcpsk.hlp, 5/2/2003 03:19:00, 24389 bytes
Driver: C:\WINDOWS\help\nvcpsl.hlp, 5/2/2003 03:19:00, 55756 bytes
Driver: C:\WINDOWS\help\nvwcpsl.hlp, 5/2/2003 03:19:00, 23455 bytes
Driver: C:\WINDOWS\help\nvcpsv.hlp, 5/2/2003 03:19:00, 54457 bytes
Driver: C:\WINDOWS\help\nvwcpsv.hlp, 5/2/2003 03:19:00, 23253 bytes
Driver: C:\WINDOWS\help\nvcpth.hlp, 5/2/2003 03:19:00, 72751 bytes
Driver: C:\WINDOWS\help\nvwcpth.hlp, 5/2/2003 03:19:00, 33425 bytes
Driver: C:\WINDOWS\help\nvcptr.hlp, 5/2/2003 03:19:00, 60678 bytes
Driver: C:\WINDOWS\help\nvwcptr.hlp, 5/2/2003 03:19:00, 25634 bytes
Driver: C:\WINDOWS\help\nvcpzhc.hlp, 5/2/2003 03:19:00, 65219 bytes
Driver: C:\WINDOWS\help\nvwcpzhc.hlp, 5/2/2003 03:19:00, 26129 bytes
Driver: C:\WINDOWS\help\nvcpzht.hlp, 5/2/2003 03:19:00, 64921 bytes
Driver: C:\WINDOWS\help\nvwcpzht.hlp, 5/2/2003 03:19:00, 26920 bytes
Name: NVIDIA nForce2 Memory Controller
Device ID: PCI\VEN_10DE&DEV_01EF&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&05
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EE&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&02
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01ED&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EC&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_01EB&SUBSYS_0C1710DE&REV_A2\3&13C0B0C5&0&01
Driver: n/a
Name: NVIDIA nForce2 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_01E8&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&F0
Driver: C:\WINDOWS\System32\DRIVERS\nv_agp.SYS, 4.12.0001.0278 (English), 9/6/2002 11:24:00, 13568 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_01E0&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&00
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_006D&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&60
Driver: C:\WINDOWS\System32\DRIVERS\pci.sys, 5.01.2600.1106 (English), 8/29/2002 12:00:00, 62976 bytes
Device ID: PCI\VEN_10DE&DEV_006C&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&40
Name: NVIDIA(R) nForce(TM) MCP Audio Processing Unit (Dolby(R) Digital)
Device ID: PCI\VEN_10DE&DEV_006B&SUBSYS_0C111043&REV_A2\3&13C0B0C5&0&28
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:34, 57856 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.1106 (English), 8/29/2002 02:01:00, 134272 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 45696 bytes
Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English), 8/29/2002 12:00:00, 22016 bytes
Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 4096 bytes
Driver: C:\WINDOWS\system32\drivers\nvax.sys, 5.10.2917.0000 (English), 12/5/2002 12:01:00, 13056 bytes
Driver: C:\WINDOWS\system32\drivers\nvarm.sys, 5.10.2917.0000 (English), 12/5/2002 12:01:00, 62336 bytes
Driver: C:\WINDOWS\system32\drivers\nvmcp.sys, 5.10.2917.0000 (English), 12/5/2002 12:01:00, 820864 bytes
Driver: C:\WINDOWS\system32\drivers\nvapu.sys, 5.10.2917.0000 (English), 12/5/2002 12:01:00, 241664 bytes
Driver: C:\WINDOWS\System32\nvack.dll, 5.10.2917.0000 (English), 12/5/2002 12:01:00, 4096 bytes
Driver: C:\WINDOWS\System32\nvasio.dll, 5.10.2917.0000 (English), 12/5/2002 12:01:00, 30720 bytes
Driver: C:\WINDOWS\System32\nvopenal.dll, 5.10.2917.0000 (English), 12/5/2002 12:01:00, 44032 bytes
Driver: C:\WINDOWS\System32\OpenAL32.dll, 5.10.2917.0000 (English), 12/5/2002 12:01:00, 44032 bytes
Driver: C:\WINDOWS\System32\ALut.dll, 5.10.2917.0000 (English), 12/5/2002 12:01:00, 5120 bytes
Name: NVIDIA(R) nForce(TM) Audio Codec Interface
Device ID: PCI\VEN_10DE&DEV_006A&SUBSYS_80951043&REV_A1\3&13C0B0C5&0&30
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_0068&SUBSYS_0C111043&REV_A3\3&13C0B0C5&0&12
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.1106 (English), 8/29/2002 12:00:00, 19328 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 8/29/2002 12:00:00, 135552 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 8/29/2002 12:00:00, 51968 bytes
Driver: C:\WINDOWS\System32\hccoin.dll, 5.01.2600.1106 (English), 8/29/2002 12:00:00, 5120 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 22:36:34, 67072 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_0C111043&REV_A3\3&13C0B0C5&0&11
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.1106 (English), 8/29/2002 12:00:00, 15744 bytes
Device ID: PCI\VEN_10DE&DEV_0067&SUBSYS_0C111043&REV_A3\3&13C0B0C5&0&10
Name: NVIDIA® nForce(TM) IDE Controller
Device ID: PCI\VEN_10DE&DEV_0065&SUBSYS_0C111043&REV_A2\3&13C0B0C5&0&48
Driver: C:\WINDOWS\system32\drivers\nvidesm.sys, 5.10.2600.0307 (English), 11/13/2002 15:10:00, 20224 bytes
Driver: C:\WINDOWS\System32\nvmdcoi.dll, 5.10.2848.0005 (English), 11/13/2002 15:10:00, 28160 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0064&SUBSYS_0C111043&REV_A2\3&13C0B0C5&0&09
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0060&SUBSYS_00000000&REV_A3\3&13C0B0C5&0&08
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/29/2002 12:00:00, 35840 bytes
Name: 3Com 3C920B-EMB Integrated Fast Ethernet Controller
Device ID: PCI\VEN_10B7&DEV_9201&SUBSYS_80AB1043&REV_40\4&35344E25&0&0860
Driver: C:\WINDOWS\System32\DRIVERS\el90Xbc5.SYS, 4.31.0000.0000 (English), 8/13/2002 21:27:00, 74338 bytes
Name: Silicon Image SiI 3112 SATARaid Controller
Device ID: PCI\VEN_1095&DEV_3112&SUBSYS_61121095&REV_01\4&3B1D9AB8&0&5840
Driver: C:\WINDOWS\System32\DRIVERS\SI3112r.sys, 1.00.0000.0032 (English), 5/9/2003 15:55:02, 89749 bytes
Driver: C:\WINDOWS\System32\DRIVERS\SiWinAcc.sys, 1.00.0000.0004 (English), 2/12/2003 12:37:48, 9600 bytes
DirectX Components
ddraw.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 257536 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 10496 bytes
d3d8.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1156608 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1613312 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/29/2002 12:00:00 33040 bytes
dplayx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 217600 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 22016 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/29/2002 12:00:00 42768 bytes
dpwsockx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 54272 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 377856 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 203264 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/29/2002 12:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 8/29/2002 12:00:00 151552 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 8/29/2002 12:00:00 168960 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 394240 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 8/29/2002 12:00:00 65536 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 76800 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 12:00:00 31744 bytes
gameenum.sys: 5.01.2600.1106 English Final Retail 8/29/2002 01:32:44 9856 bytes
dsound.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 336384 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 68096 bytes
dmusic.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 97280 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 171520 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1675264 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/29/2002 12:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 8/29/2002 12:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 English Final Retail 8/29/2002 12:00:00 21504 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 53248 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/29/2002 12:00:00 498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 17:34:40 241664 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 177152 bytes
qdv.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 268800 bytes
qdvd.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 355840 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 524800 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 1246208 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/29/2002 12:00:00 251904 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 11/14/2002 12:58:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 11/14/2002 12:58:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 11/14/2002 12:58:02 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 11/14/2002 12:58:02 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 11/14/2002 12:58:02 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 11/14/2002 12:58:04 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 11/14/2002 12:58:04 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 11/14/2002 12:58:06 154624 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 194560 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 45696 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:30 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 16896 bytes
kstvtune.ax: 5.03.0001.0902 English Final Retail 6/4/2003 10:30:32 274432 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 6/4/2003 09:18:28 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 226304 bytes
vfwwdm32.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:18 49664 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 2/17/2003 10:21:50 52096 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.0000.0900
CC Decoder,0x00200000,2,1,,5.03.0000.0900
WST Codec,0x00200000,1,1,,5.03.0000.0900
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
DMO JPEG Video Decompressor,0x00000000,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.00.0005.0830
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
VW AudioConvert,0x00200000,1,1,audconv.ax,2.00.0669.0000
VW AlphaSplitter,0x00200000,1,1,AlphaSplitter.ax,2.00.0662.0000
VW VideoCutList,0x00200000,1,1,vCutList.ax,2.00.0662.0000
DvdDump,0x00200000,1,0,dvddump.ax,1.00.0000.0216
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0900
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
MGI CrossGraph Renderer,0x00200000,1,0,MGICGFilter.ax,2.00.0662.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
VW Pan Zoom Filter,0x00200000,1,1,PanZoom.ax,2.00.0669.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
Ligos GoMotion Capture Encoder Filter (Roxio),0x00200000,2,1,GoMotionCaptureEncoder.ax,6.02.0000.0021
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
Roxio MPEG Splitter,0x00200000,1,2,RxMpegX.ax,2.00.0203.0000
ROXIO VCD/SVCD Navigator,0x00200000,0,0,Navigator.dll,2.00.0203.0000
Xing® VideoCD Navigator,0x00600000,0,2,rpds3260.dll,6.00.0008.0642
StreamBufferSink,0x00200000,0,0,sbe.dll,6.04.2600.1106
VW ThumbnailGrabber,0x00200000,1,0,thumbnailgraber.ax,2.00.0669.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,,5.2562.0015.0055
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,5.00.0002.0000
ROXIO Subpicture Decoder,0x00200000,1,1,SubPictDec.dll,2.00.0203.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
VW SpyPos,0x00200000,1,1,MGINullIP.ax,2.00.0669.0000
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
ROXIO WAV Dest,0x00200000,0,0,WavHead.ax,2.00.0669.0000
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Ligos MPEG Audio Decoder,0x03680001,1,1,lmpgad.ax,4.00.0000.0084
List Image Source,0x00200000,0,1,ListImageSource.ax,2.00.0669.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
VW Looper,0x00200000,1,1,Looper.ax,2.00.0669.0000
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.2980
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0900
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
VW MediaPlacer,0x00200000,2,2,MediaPlacer.ax,2.00.0662.0000
VW Video Effect,0x00200000,1,1,VideoEffect.ax,2.00.0669.0000
VW vlooper,0x00200000,1,1,vlooper.ax,2.00.0662.0000
VW De-Interlace Filter,0x00200000,1,1,DeInter.ax,2.00.0662.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.2980
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
VW ColorSpace Converter,0x00200000,1,1,ColorSpConv.dll,2.00.0662.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.04.2600.1106
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0902
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902
VW Input Selector New,0x00200000,1,0,InputSelector.ax,2.00.0662.0000
VW Audio Source,0x00200000,0,1,AudioSrc.ax,2.00.0669.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
Roxio Audio Decoder (DVD),0x00600000,1,1,RoxioDVDAudio.dll,2.00.0195.0000
Roxio DVD MPEG2 Decoder,0x00200000,1,1,RoxioDVDDecoder.dll,2.00.0203.0000
MGI Scene Detector,0x00200000,1,1,SceneDetector.ax,2.00.0662.0000
VW Latency,0x00200000,1,1,latency.ax,2.00.0669.0000
MGI CrossGraph Source,0x00200000,0,1,MGICGFilter.ax,2.00.0662.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0902
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0902
VW AudioMixFlt,0x00200000,1,1,audmf.ax,2.00.0669.0000
VW AudioGrabber,0x00200000,1,0,thumbnailgraber.ax,2.00.0669.0000
VW QuickGrabber,0x00200000,1,0,thumbnailgraber.ax,2.00.0669.0000
Roxio SVCD MPEG2 Decoder,0x00200000,1,1,RoxioDVDDecoder.dll,2.00.0203.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
VW Video Resampler Filter,0x00200000,1,1,VResamFilt.ax,2.00.0669.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
Sewer,0x00200000,1,0,MVWcDSutil.dll,2.00.0669.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0900
Indeo® audio software,0x00500000,1,1,,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
VW Input Selector,0x00200000,1,0,InputSelector.ax,2.00.0662.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
VW VideoInfo Transcoder,0x00200000,1,1,VWVinfoXcoder.ax,2.00.0662.0000
MGI DV Scene Change Detector Tee,0x00200000,1,1,DVSceneCDTee.ax,2.00.0662.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Audio Chunker,0x00200000,1,1,Chunker.ax,2.00.0669.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,,5.10.0002.0051
StreamBufferSource,0x00200000,0,0,sbe.dll,6.04.2600.1106
Ligos MPEG Splitter,0x00800000,1,2,lmpgspl.ax,4.00.0000.0084
Ligos MPEG Video Decoder,0x00800000,1,1,lmpgvd.ax,4.00.0000.0084
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0902
RealPlayer Audio Filter,0x00200000,1,1,rpds3260.dll,6.00.0008.0642
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Roxio Dump Filter,0x00200000,1,0,RxDump.ax,1.00.0000.0216
Roxio Video Transition Filter,0x00200000,1,0,VideoTransition.ax,1.00.0000.0216
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
Video Effects,0x00200000,1,1,vergb24.ax,1.00.0000.0216
Roxio DV Frame Detector,0x00200000,1,1,dvframedet.ax,1.01.0326.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
Multi File Reader (Async.),0x00400000,0,1,MultiFileReader.ax,1.00.0000.0216
VW Video Transition Filter,0x00200000,1,0,VideoTransition.ax,2.00.0669.0000
VW Switch,0x00200000,1,1,MGISwitch.ax,2.00.0662.0000
NVVPE,0x00600000,1,1,FILTER.AX,1.00.0000.0001
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression Filter,0x0009c400,1,1,,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00030d40,1,1,,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.0000.0900
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.0000.0900
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
DMO JPEG Video Compressor,0x00000000,1,1,,
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0900
Indeo® video 5.10 Compression Filter,0x00100000,1,1,,5.2562.0015.0055
Ligos GoMotion Capture Encoder Filter (Roxio),0x00200000,0,0,GoMotionCaptureEncoder.ax,6.02.0000.0021
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
DivX 5.0.5 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel I.263 Video Driver 2.55.016,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
MSN Audio,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
NVIDIA(R) nForce(TM) Audio,0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
MPU-401,0x00200000,1,0,quartz.dll,6.05.0001.0902
NVIDIA(R) DLS Synthesizer,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming Capture Devices:
,0x00000000,0,0,,
nVidia WDM Video Capture (universal),0x00200000,1,4,,5.03.0000.0900
,0x00000000,0,0,,
NVIDIA(R) nForce(TM) Audio,0x00200000,5,5,,5.03.0000.0900
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
NVIDIA(R) DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
NVIDIA(R) Kernel Synthesizer,0x00200000,1,1,,5.03.0000.0900
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Video Capture Sources:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming TV Tuner Devices:
nVidia WDM TVTuner,0x00200000,0,2,,5.03.0001.0902
WDM Streaming Crossbar Devices:
nVidia WDM Video Crossbar (universal),0x00200000,6,1,,5.03.0001.0902
nVidia WDM A/V Crossbar,0x00200000,5,4,,5.03.0001.0902
WDM Streaming TV Audio Devices:
nVidia WDM TVAudio Crossbar,0x00200000,1,1,,5.03.0001.0902
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00200000,0,0,encdec.dll,6.04.2600.1106
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.04.2600.1106
XDS Codec,0x00200000,0,0,encdec.dll,6.04.2600.1106
WDM Streaming Communication Transforms:
Audio Renderers:
NVIDIA(R) nForce(TM) Audio,0x00200000,1,0,quartz.dll,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: NVIDIA(R) nForce(TM) Audio,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.0000.0900
NVIDIA(R) Kernel Synthesizer,0x00200000,1,0,,5.03.0000.0900
NVIDIA(R) nForce(TM) Audio,0x00200000,14,6,,5.03.0000.0900
BDA Receiver Components:
BDA Slip De-Framer,0x00600000,1,1,,5.03.0000.0900
System Information
Machine name: MAIN
System Model: A7N8X
BIOS: Ver 1.65
Memory: 256MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0330
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
| | Service: HidUsb
| | Flags 2: 15020000
| | | Flags 2: 15020000
Gameport Devices
+ PCI bus
| Service: pci
| | Service: gameenum
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 3.1 GB
File System: FAT32
Drive: D:
Free Space: 5.1 GB
File System: FAT32
Drive: E:
Free Space: 2.0 GB
File System: FAT32
Drive: I:
Free Space: 57.3 GB
File System: NTFS
Drive: G:
Drive: H:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
BDA CP/CA Filters:
Audio Renderers:
