All, I need a little help. I am stumped
I am having some issues with an event critical error that is in my system log.
The error text is:
?The driver detected a controller error on \Device\Harddisk1\D.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.?
The Specifics?.
Source: Disk
Category: None
Type: Error
User: N/A
Event ID: 11
I haven?t had any issues with my HD but am wondering if this is a symptom of a problem to come or possibly an incorrect configuration of the driver. This is a new XP Pro install.
I have a p4vmm2 mainboard that has Dual PCI IDE interfaces - support four IDE devices (PIO mode 4, DMA Mode 2, Ultra DMA 66/100)
The HDs I have IBM Deskstar 60Gig connected to the UDMA controller and Maxtor 80 Gig connected to the IDE controller.
I am also getting this error which might be another symptom
?A parity error was detected on \Device\Ide\IdePort1.
The Specifics?.
Source: atapi
Category: None
Event ID 5
Type: error
I have done a search on the second error and found this information at Microsoft Knowledge Base
If anybody has had a similar problem or can provide guidance, I would appreciate it.
The error text is:
The Specifics?.
Source: Disk
Category: None
Type: Error
User: N/A
Event ID: 11
The Specifics?.
Source: atapi
Category: None
Event ID 5
Type: error
