I recently upgraded my wife's system with a new motherboard, CPU and ram. Here are the system specs:
MSI KT6V-LSR KT600 chipset
AMD Sempron 2400+ retail hsf
Kingston Value Ram PC-3200 512 mb
Orig, Maxtor D-740X 40 gig HD now WD Caviar SE 80 gig)
Gainward Geforce 2 Pro Video card
Windows 2000 service pack 4
orig. D-Link D-120 wireless USB NIC
currently D-Link DWL-520 PCI network card
My problem is that I lose my internet connection to the wirless access point. The card appears to be fine but can't connect. When it does this, I also have problems getting into device manager to check on the system's hardware status. It also hard locks when I try to shut it down. Once I manually shut down, it sometimes won't reboot. Then if I leave it off for a while, it reboots and everything works normally, including the internet. I assumed it was a bad hard drive, perhaps with a corrupted file in windows, so I replaced the drive and used norton ghost to clone the old drive to the new. I also swapped the USB NIC for a PCI based wireless network card. It seemed to be fixed, but now it is doing it again. It will work for days at a time, then act up. Could it be:
1. Bad CPU?
2. Bad motherboard?
3. Bad ram?
4. Bad power supply? (It is an Antec 300 watt unit that is a few years old)
5. Bad Windows?
The only other thing I have noticed is that the CPU runs a lot hotter than my old Duron 850 on the Chaintech AJA2E KT133E board. My BIOS shows around 50 to 53 C for the cpu under light load. Seems like it should run cooler than that. Any ideas or suggestions? I thought I had it fixed when I swapped out the network card. Then I thought I had it whipped when I replaced the hard drive with a new Western Digital Caviar SE (80) gig. But now it is acting up again. Kind of annoying, especially the way it works okay again if you wait a while.
Appreicate any input or suggestions as to how best to troubleshoot.
Chuck
1. Bad CPU?
2. Bad motherboard?
3. Bad ram?
5. Bad Windows?
Chuck
