herkulease
I'm pretty sure I narrowed it down to a cable problem.
heres the issue. the ide cable that came with my cdrw is too short to fit in a full tower case. I lowered it to the lowest part possible to fit both cdrw and dvdrw.
so I went a bought a new longer ide cable. system doesn't like it. went back got an ata100 cable that backwards compatible. system doesn't like it. I should be specific on the doesn't like it. xp sees the burners but I can run anything from the cdrw drive. If I connect using hte cable that came with the cdrw the cdrw will work. DVDRW drive works doesn't matter which cable I used.
now do I have really bad luck with bad cables, I'm totally buying the wrong cable or its something else.
I can make it fit my full tower(original cable) only with I can move the middle connector up a bit. is there any way I can do that?
cdrw is a Yamaha 2100ez. dvdrw - pioneer 104.
anyhelp will do.
anyhelp will do.
