- Jun 17, 2005
- 416
- 0
- 71
I hope someone can shed some insight on my situation.
Here is my setup
Gigabyte 6100 Motherboard
Athlon 64 3200+
1 GB Corsair Value Ram 3200
WD 300 GB Hard Drive
1 Sony DRU-810A
Geforce 6800 GS PCI X16
Thermaltake 430 NP Power Supply
Computer runs perfectly stable, passed every test in prime 95 for over 3 days straight. The problem lies when i move the comp somewhere or turn it off for a while, It will not turn back on. I have to unplug the 24 pin cable from the power supply from the motherboard, plug it back in the motherboard. Then the PC will turn on.
When it DOES turn on, i only get a black screen, and an unable to turn the computer off with the power button. I have to resort to using the switch on the back of the power supply. After powering off and on the PC a few times, It will finally post and boot fine, and from there i will have no problems. Aside from leaving my pc on all the time, any one have any insight as to what the problem might be?
Here is my setup
Athlon 64 3200+
1 Sony DRU-810A
