darkside9923
Ok a bit of history, I built a new PC about 9 months ago, and I do not have a Parallel port on my new DFI mobo....So I was using a back up computer that had the Parallel port and my Laserjet 2100 worked fine.
So I got sick of having to boot that pc up just to use my printer, so I purchased a Parallel to USB adapter, it is recognized by Windows XP SP2 as a HP2100 using USB0
When I first power the computer on I can print to the printer fine, but if I decide a few hours later I want to print to it, it just sits there as a job and doesn't go to the printer, nor can I delete or restart the job. If I power cycle the computer, after it posts and windows is loading it prints, but the page is blank, I can then print as many things as I would like, untill it sits for a while.
I am not running any power management, I have it set to always on.....
If I had the money I would just get the jetsend card and hook it to my router, but I don't have the money for that right now. Is there anyway I can get this to work? I can't recall but I thought there was something to type in the command prompt to route something to USB.
