Strange problem with my MSI R6450-MD1gd3/LP... hopefully you guys can help!? :(
OldPete
Ok! I am running a Dell OptiPlex 3020 with onboard Intel video (HD4600).
I am running two displays (Samsung S27D360).
No matter what I do (including disabling the Intel) I can not get MSI to display full screen. Even if I run it as a single display (no mutli display)... it still will not work properly.
Thoughts? Is this a known issue? I've tried drivers from Samsung... and I've tried drivers from MSI... nothing seems to work. :(
Thoughts would be much appreciated!
At this point, I'm willing to just buy another card and return this one if there's one that's better... (This is a PCI-E 2.0 x16 card)
Thanks!
lopri
13,327
708
Right click on desktop -> AMD Catalyst Center -> My Digital Flat-Panels
There should be desktop scaling options.
KingFatty
3,034
1) How are you connecting the MSI card to your monitor?
2) Clarify: do you mean you have a black border around the edges of the screen? Are you unable to achieve a certain resolution, such as 1920 x 1080?
Your issue might be related to HDMI overscan adjustment.
Or, your issue could be a faulty display cable that prevents you from achieving a certain resolution.
What resolution are you using when the issue occurs?
