Strange problem with memory
Snowjim
Hi,
I have recently bought the computer in the sign below.
The first memory I got in to this computer was :
Corsair 8GB (2x4096MB) CL9 1600Mhz XMS3 1,5V
Article nr : CMX8GX3M2B1600C9
This worked grate! But then I switched memmory because :
1. The "B" in the Article nr states that its a AMD specific memory, but in this case there is sticker on the memorybox stating that it is also supporting i5 and i7. Corsair says that if the computer works then there is no need to switch. But to be sure of stability I need to run Prime95 for a day or so and with stock cooler I really dont dare to do that(temp above 85 degree with prime95).
2. But then in another conversation with Corsair thay say that VENGEANCE is a updated memmory that handels OC better and have a better cooling.
So I switched to :
Corsair 8GB (2x4096MB) CL9 1600Mhz VENGEANCE LP
Article nr : CML8GX3M2A1600C9
The "A" in the article nr states that its for Intel.
The problem is that the first memoryworks grate but when switching for the new one the mouse laggs for example when logging in to Windows7 or starting Winamp. The System does however works fine, its no problem to play for example BF3 in a couple of hours.
So the question is why this problem with the new memory? I have tried to switch back to the old once and the problem is gone?
The Bios runs in auto and this means that both memories is running in 1600 Mhz at 1.5V
Have I missed a setting or why do I get this problem with the new memory?
Computer spec : CPU : Intel Core i7 2600K Motherboard : Gigabyte Z68XP-UD3P B3 Graphiccard: Gigabyte GeForce GTX 570 1280MB Windforce OS disk : Intel X25-M G2 80GB SSD Chassi : Fractal Design Define r3 Ppwersupply : Corsair 650W
