Last night I unplugged my monitor from one computer and plugged it into another. I turned it on and got a message that said "please check signal" So I unplugged the cord and noticed that there was a pin missing from the D-sub (isn't that what it's called) cable. It wasn't broke off or anything, it was just completely missing, as if something had pulled it completely out. At first I panicked, but then this morning I tried it again and now it works fine. Is there a problem here? Is it possible that the pin was never there to begin with, and isnt really necessary? Can I order a new pin to plug in to the hole (each pin appears to be plugged into its own separate hole, if that makes any sense).
