Hope someone can help with this:
I've just put together a new E6600 based machine, however the hard drive is having a weird problem (a Seagate Barracuda 320GB SATA2 drive on a Gigabyte GA-965P-DQ6):
About 50% of the time when the PC boots or restarts from Windows and the AHCI bios on the ICH8R southbridge detects the drive (connected to channel 0), it will take a little too long to find it and once it has, instead of booting I get:
"There was a disk read error.
Press Ctrl+Alt+Delete to reboot".
So I do and when it reboots it finds the disk without a problem and boots into Windows. It never fails twice in a row and once it's got past that problem it works perfectly.
The regularity and pattern of this problem are bizarre. I'm holding off installing everything in case someone says the drive is screwed, but equally I don't want to RMA the drive if it's a motherboard problem.
Any ideas gratfully received!
