I'm running into a strange problem, not sure if its related to my power supply or more random than that. When I plug in my SATA hard drive to power, my SB Audigy stops working and isn't detected by the system. However when I plug my SATA drives into the power supply of another computer (eg I'm running my system on one PSU, and only the SATA drives on a different PSU) everything works fine and dandy. If I unplug my Audigy, then my SATA drives work fine using my original PSU.
I'm running:
A64 oc to 2.6ghz
1 g ram
X800xt PE
3 hard drives (1 IDE, 2 SATA)
4 80 mm fans
1 120 mm fan
water cooling pump
fan controller
DVD reader, CD writer
Using an Antec 400 W powersupply. I was under the impression that 99% of systems only need a 250W quality powersupply.
I'm running:
A64 oc to 2.6ghz
1 g ram
X800xt PE
4 80 mm fans
1 120 mm fan
water cooling pump
fan controller
