Strange Problem Installing Video Card into NXZT S340 Case.
DarxPhil
Hey guys/gals,
I haven't heard this issue from other S340 owners, but when installing my video card the bracket that holds the video card in doesn't have screw holes to match up with my card (GTX 760). I had to push the video card back with a bit of force just to get the holes aligned, i don't think this is a video card issue as all modern Nvidia cards are using the same brackets. So maybe the case is faulty in a way where the screw holes are inaccurate?, Is it possible to just buy something like a dremel in order to just make correct holes in the case or video card bracket myself? or just a drill? (What tool would be best in your opinion?)
Thanks.
PhIlLy ChEeSe
962
Hey guys/gals,
Thanks.
The PCI-E bracket on the GPU may be bent, or you can bend it. If you do drill(which is do not suggest), make sure the shavings do not land on any PCB. And if so make sure you remove all shavings before you power it up.
