- Sep 13, 2003
- 976
- 0
- 0
I'm not sure if it's my motherboard or PS. If I shut down my computer and let it sit for a while I can't turn it back on unless I remove the power cord from the PS and wait a few seconds then plug it back in. Removing the main cable going to the mobo and plugging it back in will also allow me to then turn the computer on. Also, if I shut it down and then turn it back on a minute or so later it starts up no problem. It's only when I let it sit a while that it doesn't start.
What do you think could be the problem and what should I do?
Thanks
Thanks
