strange O/C problem
itsse03
I have a Pentium D 805 2.66ghz with stock Intel CPU fan, Asus P5LD2-VM mobo and 2gb (2x1gb Dual Channel) Corsair PC2-4200 DDR2-533.
If i use the "Auto" O/C setting in the bios to get a 10% increase, i can boot up my rig and it's stable. FSB would be at 147mhz, so the CPU would be running 147x20=2.94ghz. now if i try 15%, my rig won't post.
however if i set it to Auto at 10% and i do a soft reboot and manually O/C my CPU at 151mhzx20=3.0ghz, everything runs stable. if i do a "restart' using my OS, everything is fine and it reboots, posts and i can get back into my OS. mind you at that setting my CPU is running fairly hot, on heavy load it reached 60C/140F, but stable none the less.
but i can't get it to even post at the 3.0ghz if i turn off the machine and turn it back on. but i can soft reboot it at 3.0ghz IF i set it to Auto 10%, let it boot, soft reboot and then manually set it to 3.0ghz.
can anyone give me any suggestions WHY this would be happening? it's not like the CPU can't handle being run at 3.0ghz.
Furen
1,567
60 C = 140 F, that's what itsse03 meant.
I think your problem is the ram. If you overclock your FSB you also overclock your ram, try lowering the ram speed to see if that helps.
itsse03
sorry, yes that's 140F.
i did try lowering my ram speed but that doesn't seem to make a difference.
like i said, once i get my manual settings to take after doing an auto 10% increase, it's fine. i can soft reboot as much as i want and windows is stable.
right now running auto 10%, CPU is at 2.93ghz FSB at 146.7mhz, memory at 293.3mhz FSB:DRAM 1:2, CAS 4, RAS/CAS 5, RAS 5, TRAS 15.
if i want to run at 3.0ghz with FSB at 151mhz, what should my memory settings be running at? i've been running in auto SPD to let my mobo set it automatically, maybe that's my problem. i did try to play with the DRAM frequency and bumped it down to DDR2-300Mhz (which is usually sets to DDR2-400mhz).
