My new Sapphire HD 7850 OC 2GB GDDR5 video card installed in my new system build is emitting high pitched whistling/chirping/buzzing noise.
The noise is louder when scrolling pages, or dragging windows and becomes very louder and evident when scrolling through web pages in Internet Explorer 9 with "Use Smooth Scrolling enabled.
Considerations:
The noise does not occur when the video card does not have a driver installed;
The noise does not occur when I switch to onboard video card;
The noise does not occur when I switch to a Sapphire HD 6870 1GB GDDR5 video card;
The noise persisted switch the Power Supply (XFX 650W XXX Edition Power Supply);
The noise persisted after disabling the options "CPU Enhanced Halt (C1E)", "C3/C6 State Support" and "CPU EIST Function" in BIOS;
The noise persisted after disabling the options Audio Controller (onboard audio) and Internal Graphics (onboard video) in BIOS;
The noise is lower and less evident when Use Smooth Scrolling is disabled in Internet Explorer 9 settings;
The GPU Activity in ATI Overdrive (Catalyst Control Center) shows 60% when scrolling pages in Internet Explorer 9 with Use Smooth Scrolling enabled;
The noise stop by reducing the GPU Clock and Memory Clock using ATI Overdrive;
Ive already contacted the reseller for warranty or RMA service and Im currently awaiting their reply. Is there any other thing that I could do to solve this problem? Any help is truly appreciated!
System specifications:
Video card: Sapphire HD 7850 OC 2GB GDDR5 | P/N 299-1E221-200SA | SKU 11200-14-20G
OS: Microsot Windows 7 Ultimate 64-bit
CPU: Intel Core i7 3770
MB: Gigabyte GA-Z77X-UD3H (rev. 1.1)
MB BIOS: AMI EFI BIOS version F16
VGA Driver: Catalyst Software Suite Revision 13.1 Display Driver version 9.012 (1/17/2013)
Power Supply: OCZ 600W ModXStream Pro Power Supply OCZ600MXSP-NP
Considerations:
