I have a Linksys 10/100 PCI card on a Tyan S1833DL with 2 PIII 500 running Windows 2000 Pro. The protocols are TCP/IP & NetBUIE. The computer can access internet. It can copy files from any other computer. However, if you attempt to copy a file from this computer to any other computer (mixed Windows 98SE, NT4, 2000 Server & 2000 Pro), you'll get an unexpected network error. The other computer can see this computer and it's drive. But if you try to access the drive, you will get an unexpected error.
I've moved the card to a different slot, I changed network wires, change ip & reinstall protocols but I got the same thing. It seems that if you attempt sending files you'll have an error but if you're only getting the file, it's ok.
Do you think it's the new network card orsomething is conflicting? The only other card in this computer is a PCI STB Horizon 64 network card that has no video driver for Windows 2000.
