Strange Mouse Problem
silent101
8
Ok, so I recently installed my first motherboard. It is a ASRock 939Dual-SATA2. I also bought a Thermaltake VENUS heatsink, and an AMD 64 3200. The installation went excellent, and the computer is working fine, but there seems to be a problem with my mouse. Every time I move it, and I mean EVERY time, there seems to be a high pitch squeel/clicking coming from my motherboard. Then if i un-plug the mouse, the squeel is constant, but if I un-plug the keyboard also, the squeel stops. It is not a really loud squeel, but it can be easily heard over this heatsink, and if anyone knows about this heatsink....it is loud. I do not have any spare mice/keyboard to try, just wondering if anyone has had this problem. Thanks for any help.
Fardringle
9,200
765
If it happens even when the mouse is disconnected completely, I'd say it's a problem with the keyboard and not the mouse. Do you have a spare keyboard (even a junky one) you can try to see if the same thing happens with a different keyboard?
